The official MACAN AFTERMARKET RIMS thread
2 reading
849K views 906 replies 315 participants last post by  Upwave
#1 · (Edited by Moderator)
Let's see some of YOUR favs. I think the optimum wheel size for the Macan is 21" at most... 20 or 21's would look perfect, whereas 22 would probably be a bit too big.
Here are some rims I like & some websites of some good companies. Feel free to click the links below & enter the subcategories then save & post any pics of rims you think would look good on the Macan!
edit-Forget the colour of the rim in the picture. ALL rims come in silver, black, and chrome. Just looking for the actual style of the rim. Personally, I'm looking for black rims for my white Macan & any rim that is in silver below also comes in black which is great. I just posted a bunch of different options.
Links:
Forgiato Wheels | Forgiato Wheels
Asanti Wheels
PREMIERTIRE.CA - TIRE AND WHEEL DEALERS IN TORONTO (then click on wheels for TONS of options)
#150 ·
The spec here is et4 rear, et23 fronts (20x9.5 et29 all 4, 25mm spacer rear, 6mm spacer front)
275x45-20 tire x four.
I had to put an unplanned 6mm spacer in the front, since the wheel was touching the caliper. I needed about 3mm to clear, but had some spacers left over from my S4 that fit. This made my front bolts to short though, so I used some longer cone seat bolts i had laying around.
Now I need to order 10 more bolts that are 6mm longer than the Tikore rears.
The tire reduced the gap some as well. Its 10mm taller than the stock ones.
Ill clean the car up soon, and take some final pictures. These are off a phone, and the car is dirty. Was a long day sorting this out though.
#152 ·
Great wheels!
LOU: Do you think whether 20x10 et25 wheel with 275 tires will work in the front? I am thinking to go 20x10 et25 all around for summer (with 15mm spacer in the rear).
Thanks!
#155 ·
They are good choices. OZ makes flow forming wheels too. Check out tirerack.com.
I have the OZ wheels on my BMW. They are light and strong. Paint and finish are nice.
#159 ·
I just order my summer wheel set-up. Niche misano t 61 monotec forged in gloss black:)
#161 ·
So < $10K is cheap out?
#163 ·
10k each, no 10k for the set rims and rubber. I am talking a set of rims made to your exact specs. Not a set you can go to a shop and pick off the wall. And no I am not saying that 10 k is cheaping out. All I am saying is why buy a rim that is cheap and weights 35 pounds each to put on a porsche. To each his own.
#165 ·
These 18" BBS SRs weren't expensive, the quality is great
For comparison to 21" Turbo 911:
