981 - 1,000 of 1,070 Posts
The cig socket will shut off after 20 mins (I believe) this is a feature as things like dash cam and cabin ionizer (I have) would stop having power after that time. No parasitic draw on that socket anyways. It would only become active when you wake the car up, which you’ve discovered. There has been a lot of postings on this. Don’t quote me on this but I think it may actually keep charging after the set time if it’s plug in the back socket…not sure if in the front. I just use the one in the hood.
Yes if charging from that port, it doesn't shut off after 30 minutes. If it's already shut off, I've found you need to at least turn Ignition ON in order to 'wake up' the 12v port
So I did some more testing and found some interesting results:
  1. After not having driven the car for a few days, I tried to trickle charge with the NOCO, but all I got on the charger was a flashing red light, indicating it wasn't charging.
  2. I unplugged and replugged (if that's a word) the charger a couple of times over 2 days, always with the same flashing red light
  3. A troubleshooting tip was to see if the fuse had gone. I validated the fuse was fine
  4. I turned the Macan to the Ignition ON mode (without actually starting the engine) and tried the charger again. Instantly, I got a solid red light, and charging began
  5. It's now been charging from about 9 hours (NOCO indicates for a 95ah battery it could be around 15 hours for a full cycle).
  6. The Macan did not cut off power to the 12v socket after 30 minutes
  7. I suspect that by tomorrow morning, the 12v socket will be disabled and the NOCO will be flashing red
Actually, what you are describing is the same behavior I have seen on my 2016. After the engine is off for 30 minutes, you can not charge thru the auxiliary power ports. That explains your numbers 1 and 2.
Turning the key to the first position re-energizes the port and makes it available for charging or powering devices. That explains your number 4.
Once charging, it will go on indefinitely and even if power is cut to the charger, it will continue charging once power is restored. i.e. the port will not be shut off, unless you power a device for 30 minutes. This explains your number 5 and 6.
your number 7 will not be born out in the morning. Charging can still take place. Try it and see.
The NOCO is now running in maintenance mode, pulsating a steady green light. Its been 36 hours and everything looks good
The overlooked thing is, if you had activated the Macan charging mode once and then stop charging, the activated charging mode will drain significantly more idle current from the battery as it does without. After two weeks parking in this situation (charging mode activated, battery fully charged then charger diconnected) my battery was once almost empty...
That was the reason for me to install a directly connected "always-on" external charging connector and charge the Macan only after the 30mins until the auxiliary sockets are turned off.
The necessity to recharge the Macan also became quite rare since I deactivated both recuperation (micro-hybrid) modes in the gateway module (coding w Launch).
Interestingly battery manufacturers like Banner of Austria explicitly state that such a micro-hybrid implementation cannot charge the battery properly!
The overseen thing is, if you had activated the Macan charging mode once and then stop charging, the activated charging mode will drain significantly more idle current from the battery as it does without. After two weeks parking in this situation (charging mode activated, battery fully charged then charger diconnected) my battery was once almost empty...
That's quite interesting. I'm not able to deactivate any modules. I will pay attention though as to when I stop the charge mode and leave it on until I drive away.
Several years back years I spent a fair amount of time in this thread and experimenting with techniques to keep the 12v outlet in the rear storage area connected while charging. Sometimes it worked, sometimes it didn’t. If you read all of the nearly 1,000 posts you will see that many had similar frustrating experiences. Because of the inconsistency I hard wired a CTEK pigtail to the battery under the spare tire in the rear storage area. The pigtail can either be tucked under the cover when not being used or left out when connected to a CTEK charger. Others hard wired to the front jump posts. (I was not a fan of this location because the exposure to weather). Whatever the location I wish I hardwired the pigtail sooner rather than later. It is crazy that such a basic thing like hooking up a trickle charger could generate a thousand posts but that’s the way it sometimes is with a Porsche.
Reactions: Robert M and reguy
In eastern/northern Canada, there’s always a plug out in the grill for a block heater.
For charging, the one I’ve seen here that’s the most convenient is the magnetic type port. Mounted on the bumper itself if I recall right. My process is still opening the hood and connecting. It does get tiring.
Did you hardware to the negative terminal or to a body panel?
Many of the cars owned by my clients all utilize some type of magnetic attachment for the charger. Super convenient and very stock looking and they can be installed with basic tools. You just have to get over the fear of drilling a hole in the plastic bumper cover or wherever you decide to install it.
There is a body panel ground point in the vicinity of the battery that I used. It may have been the bolt that secures the subwoofer. One of the custom audio guys that was participating in the thread suggested that it was not a good idea to ground directly to the negative battery post. I forget the reason. I posted pictures of the installation. I’ll try to find and give you the post number.
Edit:
It is post #254 this thread.
One of the problems with using the jump posts under the hood for charging is that the hood was not designed for the number of opening and closing cycles as was the rear hatch. The other down side is that engine compartment is not totally water tight as is the rear storage area. A magnetic type port installed in the bumper will also be exposed to the weather, not to mention drilling an unnecessary hole in a very expensive part.
First, @TigerMac is an authority on this subject because of the serious research he has done. Cudos to him for this.
With a battery maintainer, it is best to keep the connection live and connected to it until you need to drive. This avoids the issue.
Been using the accessory port for charging with a maintainer that is always connected while in my garage for several years and have not had the first issue with it.
Do you have any support for that statement? Also, Porsche tells you to charge the battery if you don’t drive the car regularly (I’m paraphrasing) and they tell you to use the jump posts?
Just common sense and what you can feel when opening and closing the hood as opposed to the rear hatch. The average Macan owner or any car owner for the matter opens doors and / or the rear hatch many times more than the hood is opened. Heck, with the Macan you don't even need to open the hood to check the oil. Can't you feel the heft and sturdiness of the rear hatch as compared with the hood?
It was designed to handle the weight, and Porsche tells you to charge it that way. So, no factual support.
I know it’s been said before but apparently not lately. There’s no need to open the hood to use the charging posts if you hook up a CTEK pigtail and leave the plug hanging out by the driver’s windshield wiper.
Lots of posts on this earlier in this thread.
I considered connecting the pig tail to the jump posts since it is probably the quickest way to go . However, as I didn’t want to subject the hood to unnecessary frequent opening and closing or have the pigtail connection exposed to weather, I went with the direct connection to the battery in the rear storage area. It takes a little longer but I think it is a cleaner installation.
