The Malaysian fb post is a CN aftermarket product which replicates the latest 2019-2021 headlights plug and play, they give replacement mounts which is just bolted by 2 or 3 screws. They are identical but does not have the porsche lettering badge inside the headlight. It however does not have adaptive cornering lights.
And it requires the 2019 oem headlight rubber seal, the older headlight seal does not fit on the 2019 aftermarket headlight.
It would only need a manual alignment and require an auto coding tool from any high end version coding tools like PIWIS or autel maxicom to enable the high beam function.
There is a way to retrofit the original 2019-2021, requires modification of wiring plug, but the coding part is more tedious with trial and error.
I would highly recommend going for the CN aftermarkets instead, the LED quality is identical.
Difference is the adaptive corner light. I do not find it a necessity but it does add some safety being able to increase tight corner visibility for others and yourself.
