I have a 2017 base I purchased 3 months ago (44,000mi). PDK oil was changed at 38,000. I noticed an occassional hesitation/stutter when accelerating at lower speeds. 3rd or above not noticeable. Reading these forums I thought that maybe there is some transfer case issue starting to develop. I replaced the fluid this past weekend with Porsche fluid. When I removed the fill plug no fluid came out. I got around 300ml from the bottom drain plug. I suctioned out from the fill port but unfortunately did not clean out all the fluid from my extractor from when I did BMW differential change so I am not 100% sure exactly how much additional fluid was removed in total but I was sucking air. There was a little over 1l of fluid in the extractor, and the BMW diff holds a bit over 800ml , so I think around 200 was extracted..but I can't be 100% sure of the amount. The fluid was quite dark (pretty much black) and seemed a little thinner than the fresh oil. When filling I was able to get around 250ml of fresh oil in from fill hole until it started to spill out (which seems consistent with what others have noted). I then removed the vent cap and pumped in another 300ml (since some spilled out and gets stuck in pump tube I felt that would compensate). Over the past few days (16 miles round trip commute with several stops) I noticed it seems to have the same 'slipping' feeling and hesitations but maybe a bit more noticeable with the new fluid. I have seen different info on the volume of fluid, some say 500ml and others say 600ml. If it is truly 500 then maybe I have a little too much fluid (if I didn't get out as much of old as I thought) but if 600 maybe I have a slightly too little. Would those small over/under numbers cause this issue?
I am thinking of pulling the fill plug and seeing what happens, if I pull the fill plug and nothing drains out should I just squirt some in from that fill port until it starts to come out like when filling a differential?
I understand TC is covered on my car until Nov 2023 but I fear it will only really fail in Jan 2024 and I will be stuck. Hoping to keep it functioning OK until closer to warranty expires for replacement so it lasts past coverage expiration.
Thanks for being a great resource to a new-to-Porsche owner. There is great info here - and I read a lot of these forums before I bought my Macan.
