41 - 60 of 560 Posts
Discussion starter · #44 ·
What Model is the Head unit to the right?
See below. If you are going to order one, you should wait until I release video with review. There are some quirks that I think you should be aware of. Nothing biggie, unless you find that one of the issues is a deal breaker…
12.3 Inch Car Radio For Porsche Macan 2013-2018 Android Auto Multimedia player GPS Navigation WIFI Carplay Head Unit
Discussion starter · #47 ·
I purchased Gen3 OEM knobs, and although they would not fit as the hole is smaller than the knobs this unit had, I was able to carefully drill some material out with the right drill bit… and pushed them in…. The result, magnificent. It does look more OEM now….
New OEM knobs:
Original knob:
New knob (next 3 photos):
Is there an micro-SD card slot on the system or can it use the Macans USB port for additional data storage? Wondering how you copy files to the unit.
Discussion starter · #52 ·
There are 2 USB ports. One that connects to the USB port in the center console for audio. The other one is for data, which you can use for what you describe.
It can't be removed. Not sure what they were thinking. But, I have gotten used to it.
what!? on what planet do we need a speed warning on an aftermarket radio?
i don't think my OCD would let me live with that. it's all i would be able to see when i get in the car.
Discussion starter · #57 ·
Yes, is asinine... I have bombarded the vendor with this, telling him I have dozens of followers in my channel that are very interested in buying, but won’t as long as that red warning is there. I’m covering mine with a NFC button, let’s see how it looks. But it doesn‘t bother me anymore. The screen itself looks very good.
Any performance difference between the first and second one? I prefer the physical buttons on the first — matches the 2018 setup a bit more.
Discussion starter · #59 ·
No significant difference. Works well, in terms of audio quality and performance. But it seem more like an afterthought from the physical installation perspective. The vents are gloss, which do not go well with the rest of the center console. The vents are open, and very small, with significant restriction to air flow. The side trims are not as polished and look somewhat different from the rest of the trims in the car.
On the other hand, this unit, even without physical buttons, looks more OEM and built for purpose. Vents are same or similar material as center console. They are bigger and actually have dials to close them independently, just like with the side vents. The side trims look OEM. There are details on the top of the unit and the bottom of the unit that cover gaps better. The only minor issue for me if the permanent red sticker, but I'm looking at options on how to address.
Overall, there are more positives to the second unit, even though both have their own quirks.
Discussion starter · #60 ·
Some side by side...
This photo shows first unit, you can see how it doesn't cover the part where the AC vent was before...
This is the second unit, and it covers everything, leaving no gaps exposed...
The first unit, the vents are glossy, smaller and don't have any way to close them, but if you see below the vents, there is no trim cover and that leaves a hole where you can see the all the way in when light hits...
The second unit has vents that are matte and combine better with center console material. Vents are bigger and can be closed. And lastly, it does have a trim cover that covers the gap between center console and vents.
