Has anyone else had this happen?
Earlier this week the yellow tire pressure warning light came on. The TPMS claims all four tires are a bit low (~1 psi) but the passenger rear tire is the one on the graphic that it's trying to warn me about. The fill display says it needs a few PSI (I forget how much).
I've been monitoring the pressures all week on the TPMS display while I'm driving. The rears start out at 36 and may rise to 38 as I get going. The pressure is supposed to be 36.
I also checked with two different gauges while the tires were cold. Both said 38 or 39.
So why is the TPMS complaining? All the tires are actually about 1 or 2 PSI over the specs (33/36 for 19" wheels and partial load).
The TPMS is obviously incorrect. I guess I'll have to bring the car in. Ugh. On the other hand, why should I bother? I know the pressures are fine. Maybe I'll skip the time-consuming visit to the dealer and just deal with the yellow light. Unfortunately I'm not due to go back in to the shop until next summer, so it may not get fixed until then if I wait.
