I power bleed my Corvettes, its quite simple, suck all the master cylinder fluid out first and replace with clean fluid.
I then bleed the drivers front first, as that empties the master cylinder quickest, then I go to the pass front, drivers rear and passenger rear last.
That is the opposite of what I usually do for a bleed, but with a pressure MOTIV Power bleeder it makes it quick, if I go to the right rear first its a waste of more fluid IMHO than going to the closest and working back to the farthest.
I have a lift and am able to remove all four wheels easily, as my Corvettes have dual bleeders as they apply pressure from both the inside and outside and do not have a standard caliper in which only one side applies pressure and the other side gets pulled not applied.
Its not hard or expensive to do, its about Porsche knowing it was done, its about them not being able to deny warranty
