quick question: Android + Spotifiy with PCM
18K views 13 replies 10 participants last post by  AnnieYazbeck
Hello. Excuse me for my quick question: I placed an order for a Macan S that comes with PCM. I don't use an iPhone but an Android OS phone. Can I hear music from my phone using the Spotify app through the Porsche Bose Sound system? If yes, does the song title and other information displays in the PCM 7" screen? Thank you!
#3 ·
I have a Macan GTS on order and I didn't realize this either. Great news. So there is no need to use a USB cable or have Porsche Connect/Connect Plus?
Is there any point in Porsche Connect/Connect Plus if I don't want an iPhone? Is there any way to use any Google apps like maps? I did order Nav module for PCM but I'd prefer Google maps.
#8 ·
I installed a PCM3.1-AV 970 from Nav-tv.com. Its basically a screen mirroring device that allows you to see your iphone or android screen on the PCM 3.1. Part plus intallation ran about $1,500. I use Waze all the time with it and also have the All Dials app to stream live radio or you can also use spotify when using Waze or stream from Apple Music or any other apple music app. Not totally ideal as you have to activate apps from the phone but if you set your phone up correctly it's pretty easy and non-distracting to use. Have had loaner Cayenne with Apple Carplay and apple maps still not great compared to Waze or Google maps though the control of music and radio is a bit easier while running map function.
#10 ·
to answer the OP's question, yes, you can definitely sync your phone to the car via Bluetooth and you'll receive phone calls and can make calls. spotify/Pandora/google play music also works via Bluetooth.
It is very finicky in my opinion. theres a certain order of events that should happen to get the music to start working from when you get into the car.
mine works like this, lets assume everything is off (the car, Bluetooth on your phone, and the music app's are all closed)
1. get in and turn on the engine
2. open the music app that you want to play (spotify, google play, Pandora)
3. turn on Bluetooth on your phone
4. click the "source" button on the Macan to switch over from Tuner to Source.
It's so annoying that sometimes I have to turn off Bluetooth, close the music app, and redo everything to get music playing sometimes. Its a lot to do while you're driving. I try to get it all working while the car is warming up for 1 minute.
Another question for those who connect their Android phone to the USB in the glovebox: how fast does it charge your phone? Does it compare to the Anker / Aukey charger speeds? ...
