701 - 720 of 1,597 Posts
22 boost gauge working
instrument cluster > board computer menu configuration - board computer menu configuration byte 0-boost pressure (bargraph) > enabled (default: disabled)
instrument cluster > coding value-coding byte 0-icon boost pressure visible > yes (default: no)
instrument cluster > further codings-max. boost pressure > 1.5 bar (default: 1.0 bar)
instrument cluster > further codings-sport boost pressure > 1.5 bar (default: 1.0 bar)
instrument cluster > further codings 2-further codings 2 - byte 2-boost pressure bargraph display with sport response > yes (default: no)
Cool...get the intersection lighting enabled......that is so cool to see at night.
Just coded that, not sure if it's going to work or not. It did throw an error in the dash when I enabled it, from your post, I went ahead and cleared the error and reran the pdls test in the x431.
@Teddis The car already did the right and left turn light up the curb areas before I farted with it, I assume yours did as well since you also have pdls+, so I need to go see if both sides light up at an intersection once it gets dark tonight. Still light out here.
Anyone want to help me hunt down this 3 minute timer ?
I checked air conditioning module since it's in the "air conditioning and ergonomics" section of the book, but I may be missing this code or it exists somewhere else. Southern California air smells like a fart and I don't particularly wish to smell the outside air coming in so trying to keep recirculation active and stay active while I drive the car, regardless of their warning.
Id like to keep the recirculation on indefinitely when button is pushed
Id like to keep the recirculation on indefinitely when button is pushed View attachment 261756
Only way I’ve got it to stay on is by turning the AC to on.
I just went through the very limited options I saw with the x431 and it doesn't appear anywhere. I also can't seem to find the vehicle in motion stuff where I can actually use the pcm while moving but there's a lot more menus in the pcm.
Thank you for the tip @lyricgskills
Where can I find it?
You know that High beam assist is not the same like pdls+
In Excell file You can find only High beam Assist
