221 - 240 of 1,596 Posts
Here is a list of the items I coded on my 2018 S using the LAUNCH.
Front End Electronics
WWS Coding
WWS-coding-Teardrop Function active
Coding
Coding_0
Coding-Comfort functions-Window comfort opening
Coding-Comfort functions-Window comfort closing
Instrument Cluster
Extended codings
Extended codings_0
Extended codings-Max. boost pressure 1.66=25PSI
Extended codings-Sport boost pressure 1.66=25PSI
Board computer menu configuration
Board computer menu configuration_0
Board computer menu configuration byte 2-mirror fold-in
Board computer menu configuration byte 4-expert menu
Board computer menu configuration byte 0-boost pressure (bargraph)
Board computer menu configuration byte 4-G-Force
Board computer menu configuration 2
Board computer menu configuration 2 byte 2-Joker Sport
CODING SEARCH – Performance Display
Board computer menu configuration byte 7-Performance Display
Kodierwert
Kodierwert-Coding byte 2-Driver seatbelt warning Deactivated
Kodierwert-Coding byte 2-Passenger seatbelt warning Deactivated
Kodierwert-Coding byte 2-USA seatbelt warning Deactivated
Kodierwert-Coding byte 2-Acoustic seatbelt warning Deactivated
Board computer display configuration key 1-4
BC Configuration byte 8-Door unlocking setting
BC Configuration byte 9-locking-mirror fold-in
BC Configuration byte 4-BC Role G-Force
BC Configuration byte 13-Performance Display
BC Configuration byte 22-BC Role Performance Display
PCM
Coding value
Coding value_1
VW Coding Value Textual-Bit field (4)-byte_23_Initial Disclaimer
VW Coding Value Textual-Bit field (4)-byte_23_Legal Disclaimer
Thanks for sharing the list Sterod, and me helping me initially to get going !
The very last section , PCM.....what does that enable ??
Santrix, so you added “High beam assist“ with one line code change ?
is this the same as intersection lighting ?
I guess I am confused on what all PDLS+ includes.......thx.
PDLS+ is PDLS plus the High Beam Assist and Intersection Lighting features. It's likely two code changes, one for each. I haven't looked for them both yet. My Macan has the camera for rain sensing wipers, but it doesn't have Lane Keep Assist so while I have PDLS, I don't know if I will be enable to enable PDLS+ as I might be missing the correct camera.
Guess you need to have someone watch you approach an intersection, LOL
You know when you turn the wheel to the left, and an extra light comes on that provides additional lighting to the left/front of the car? Think of that, except that intersection lighting lights up BOTH sides at the same time as you approach an intersection. You should definitely be able to see that occur as your approach an intersection. Be aware that this is not perfect, nor perfectly consistent as to when the lights come on. This is driven by GPS/NAV (if you don't have NAV in your car, enabling intersection lighting yields nothing).
Got it....so what other feature makes PDLS plus ?
Hmmm - this may depend on the year/options. I thought all Macan's came with the static cornering lights (the "left/front" thing I mentioned above). It appears not. On 2021 models, in the US, this is what you get with PDLS+ (see below). I can't speak to what came with Macan's in other years, in other countries. You'll need to check your owner's manual.
  • Dynamic Cornering Light
    Dynamic cornering lights swivel the low beam in accordance with cornering characteristics, depending on the steering angle.
  • Static Cornering Light
    Static cornering lights are activated based on steering angle at low speed in tighter corners or while stationary.
  • Speed-Dependent Headlight Range Control
    Speed-dependent headlight range control increases light distribution after 3,300 feet at 68 mph or higher, or immediately after 81 mph and above provided the steering wheel is not turned sharply.
  • High Beam Assistant
    When a camera located inside the rear-view mirror detects the headlights of an oncoming vehicle, the high beams are automatically turned off at a distance of approximately 2,600 feet. If the taillights of a vehicle traveling in front are detected, the high beam is then turned off at a distance of approximately 1,300 feet.
Don, so having the "A" come on...like demonstrated in your video....does NOT mean that PDLS + is active ?
A is for high beam Assit which can be toggled on and off. This has nothing to do with intersection lights which is always ready when the headlights come on.
As mentioned above. Intersection lights is another option you need to enable in the headlights under coding.
When we get PDLS+-via-Launch coding figured out, I actually plan to disable my automatic high-beam, unless I can also figure out how to change the sensitivity. I find it annoying that they do not come on unless it's super dark outside, and the whole thing about not coming on at speeds under 38mph.
While I'm ranting: Second gen Macans don't have dedicated front fog lights. In fact, my 2021 US-spec Macan doesn't have front fog light functionality of any sort. Only a single light in the rear comes on when I pull the fog switch (as documented on page 125 of the manual). My wife's 2019 Cayenne, which also doesn't have dedicated front fog lights, uses lights within the main headlight housing to provide fog light functionality It appears to me that her car is just using the static cornering lights. I wonder if something like that can be enabled on the second gen Macans?
Do second gen Macans outside the US have any front fog light functionality?
