Since no one seems to cover the basics, I'll start at the beginning:
I AM NOT AN EXPERT - I HAVE BEEN WRONG MANY TIMES. If you dork up your car, that's on you. You definitely run the risk of dorking up your car when you mess around with these tools. You can definitely muck this up so badly that only someone knowledgeable with a PIWIS can fix things - like your dealer.
If you're going to be using this for more than a few minutes, make sure you get an external power supply. I have this one.
The PMBC-55LK Series charger was designed to provide clean constant fixed output power to a vehicle during reprogramming and diagnostic servicing.
www.batterystuff.com
Steps I followed to code off the seat belt chime on my 2021 GTS (USA Market) - note that the warnings on the dash still display.
- Boot up the x431 and make sure it has a good battery charge
- With your key in the car (I just put it on the dash), or with your key in the ignition, turn the car on (do not start the engine)
- Turn off the headlights as much as you can, turn down the stereo, close the doors - consume as little power as you can, but leave the PCM screen on (that's the way I've done this work)
- If you are using external power (probably not needed for this quick config), this is when I turn the power supply on and connect up the clamps (red clamp first!) to the posts under the hood (close to the windshield)
- Plug the x431 bluetooth dongle into the OBD2 connector in the driver's footwell
- On the x431, tap Diagnose
- Scroll down and tap Porsche
- On the screen that shows you what version of Porsche software is loaded on the x431, click on "Search bluetooth' at the bottom
- Click on "Automatically Search"
- It should pop up a window confirming your VIN/Year/Model - click OK
- Click on "System Selection"
- Click on "Instrument Cluster"
- Click on "Code/brush Hiding"
- Click on "Brush Hidden/Modified"
- Click on "Search for Coding Items"
- Type "belt" (without the quotes) into the search window and click ok
- Click on "Warning configuration-Airbag warnings-Seatbelt warning acoustics (35)"
- Click on the top "Information" row where it lists the coding value as "Activated"
- Click on "Deactivated"
- Click on "Write Code" (at the bottom)
- Hopefully you will get a confirmation popup that says "Coding Success" - click OK
- You can now use the back-arrow button at the very top left to back out all the way to the main x431 menu
- It will prompt you, with the old phone tone that sounds like you left the phone off the hook, to remove the dongle
- Unplug the dongle and replace it into the storage slot on the x431
- Unplug the external power (close the hood)
- Cut off the car
- Lock the car
- Wait a while (I waited at least 20 minutes)
- Enjoy your lack of seatbelt chimes as you WEAR YOUR DARN SEAT BELT (I have been faithfully wearing my seat belt since 1977, I don't need a reminder)
If you want to use your remote to open and close the windows/sunroof via press-and-hold the lock/unlock buttons, then follow the same basic instructions as above, but change these settings in Front-end Electronics (instead of Instrument Cluster):
- Search on "comfort"
- Change and "write code" the "Coding-Comfort functions-Windows comfort opening" setting to "Yes"
- Change and "write code" the "Coding-Comfort functions-Windows comfort closing" setting to "Yes"
- Change and "write code" the "Coding-Comfort functions-Roof system comfort opening" setting to "Yes"
- Change and "write code" the "Coding-Comfort functions-Roof system comfort closing" setting to "Yes"
NOTE: Changing this setting may impact what happens if you have enabled mirror folding upon lock. Mine seems to be working as expected, but, one time, the mirrors didn't fold in like I expected. I'm not sure why. If you have Entry and Drive, you can press and hold on the door handle to lock and close everything up, too.
If you want to change your one-touch turn signal number of flashes from 1 to 4, go to Front-end Electronics:
- Search on "touch"
- Change and "write code" the "Exterior lights parameters-One touch flashing cycles" to "4".
Other stuff to figure out:
- Rear hatch close with remote - still TBD
- Disable passenger air bag warning chimes (leaving the dash warning display active) - Still TBD
- Intersection lighting (I have PDLS+)
- Headlight: Coding-Byte 4-Intersection Light. Set to Active.
- Both rear lights on for when fog light switch is on - Still TBD
- Side-marker Light flashes with corresponding turn signal
- Front-end Electronics: Coding-Exterion lighting-Exterior lighting: SMK flashes in sync. Set to Yes.
- Disable chime when door is open while engine is running - Still TBD
- Disable locking chirp
- Front-end Electronics: Coding-General-Acoustic feedback for locking (only permitted in North America). Set to No.
- Enable extra functions for "Joker" button (the steering wheel customizable/diamond button). Note: this will not enable features you do not have (Sport Plus, Sport Exhaust, PASM, Surround View, etc.)
- Instrument Cluster: Board computer menu configuration-Board computer menu configuration byte 2-Joker Sport: Set to activated to enable Sport Mode in the joker button "Vehicle" options menu (confirmed this works)
- Instrument Cluster: Board computer menu configuration-Board computer menu configuration byte 2-Joker Sport Plus: Set to activated to enable Sport Mode Plus in the joker button "Vehicle" options menu (confirmed this works)
- Instrument Cluster: Board computer menu configuration-Board computer menu configuration byte 2-Joker PASM: Set to activated to enable PASM in the joker button "Vehicle" options menu (confirmed this works)
- Instrument Cluster: Board computer menu configuration-Board computer menu configuration byte 2-Joker lane departure warning: This option does not actually work (see below for LDW)
- Instrument Cluster: Board computer menu configuration-Board computer menu configuration byte 2-Joker Sport exhaust system: Set to activated to enable Sport Exhaust in the joker button "Vehicle" options menu (confirmed this works)
- Instrument Cluster: Board computer menu configuration-Board computer menu configuration byte 2-Joker Start/Stop: Set to activated to enable Sport Mode in the joker button "Vehicle" options menu (confirmed this works) - I think this is enabled by default?
- Instrument Cluster: Board computer menu configuration-Board computer menu configuration byte 2-Joker RTV: Set to activated to enable Surround View in the joker button "PCM" options menu (confirmed this works)
- Instrument Cluster: Board computer menu configuration-Board computer menu configuration byte 2-Joker Spurverlassenswarnung: Set to activated to enable Lane Departure Warning in the joker button "PCM" options menu (confirmed this works)
- Instrument Cluster: Board computer menu configuration-Board computer menu configuration byte 2-Joker PCM_MAP: Set to activated to enable the Map in the joker button "PCM" options (NOT confirmed that this works)
