Does your front end hop and skip on tight turns?
50K views 105 replies 68 participants last post by  scornwel
Mine just feels like it has a tight diff or different turning arcs for the front wheels when using a lot of lock - particularly when going right out of a junction first thing in the morning. The front tyres seem to skip or hop to get back in sync with each other. Do they all do this? It can make for jerky and mechanically unsympathetic quick exits from junctions. Cheers
#39 ·
When I test drove mine the salesman demonstrated a full lock turn in the parking lot, emphasizing how smooth it was at how it followed a circle perfectly. So I don't think yours should do what you're describing.
The issue doesn’t tend to reveal itself until there is a bit of wear on the tires, sometimes as little at 7000km. All at very low speed eg. Turning into a parking spot
Merc GLC63s does it too. Apparently it doesn’t do it on LHD models but when built as RHD it does.... some compromise must have been made in the steering geometry. They don’t do it new and the sales guys don’t tell you that it will happen, they leave the service guys to face into the issue.
#40 ·
This has been discussed repeatedly. It’s not unique to the Macan, nor unique to Porsche. Mercedes GLC’s do the same thing. Just look at the GLC forums and you will see all the same complaints.
#43 ·
Hi Everyone
I'm living in Dublin in Ireland and have a 2017 Macan S Diesel which is by faaaaaar the best car I have ever had - and I have had a few !!
One thing that is causing some concern is that when reversing, or turning very slowly, a 'grinding' noise can be heard. It is like a shuddering, which does not occur at higher speeds i.e. when driving normally. Someone said it may be the wide tyres (Pirelli P Zeros)
Also, recently, and after just replacing the back tyres, there is another disconcerting clicking when changing up thru the gears, when giving it a little wellie. I tried this under the changes to the Chassis (sport and sport extra) but it really only changed it a little. I wonder if it might be a problem, or perhaps (no that I think of it) a little dirty fuel - what they used call 'pinking'
All advice gratefully received
Thanks
#46 ·
It's also very noticeable with the wide summer tires on our one week old 911 on a cool morning before the tires warm up when turning sharply in reverse (maneuvering in the driveway).
Reactions: Digs
#47 ·
I’ve noticed what I instinctively can describe as a tire scrub even though I know there is already a formal definition of tire scrub. Let me describe.
This occurs immediately after I start moving the car while turning. Like when I am backing or forwarding out of a parking space and making a 90 deg turn at the same time. There is a short, staccato grunt which can be heard and felt, coming from the tire(s). If there is a painted parking line that a tire crosses, the grunt/scrub happens even more obviously. It only happens once per incident.
Anyone else experience this? I am assuming it has to do with the wide tires doing a very short skip (scrubbing) on the ground to relieve tension caused by the car moving in a direction different than the tire direction for a brief moment. (I have 21” wheels, so 265/295 tire widths).
#48 ·
I had this & it went away when I got new Michelin tires.
It felt as if coming from the rear but must have been coming from the fronts.
#51 ·
@woodypup: Search!
Read the following - ESPECIALLY, rules 10 and 12:
and the posts here:
#52 ·
#53 ·
The dealer just replaced my transfer case after determining the above issue was the TC. This did not fix the issue. Turning into the driveway last evening the safe issue happened again. Has anyone had this issue?
This is my second Macan and the 2019 model had no issues.
#54 ·
I created an account to comment on this!!
I put my 2022 macan s in the shop after 4000 miles after the same issue you are having. Before I left, I test drove with the lead technician. I demoed by turning left to a parking spot and after the thump, the technician went “yup”. He said it was more “profound” in the 2022 model year than others. It apparently is not an issue… they said they won’t be doing anything on it but hopefully it gets reported to Porsche hq and have this issue resolved!!! I wonderwhat they will tell me on Monday regarding this issue.
#55 ·
My ‘22 S does this occasionally when making a slow tight turn. It feels like the front wheels are deciding whether or not to release traction.
I don’t really worry about it.
#57 ·
This happens on our 2022 base as well at low speeds when turning into parking spots usually. I figured that it was normal and had something to do with torque transfer/anti slip/automatic braking on the all wheel drive system. I’m usually taking a very sharp turn into a parking spot and there is often loose gravel or debris in parking spots so I haven’t worried about it much. I’d be interested to hear if Porsche figures out how to improve this on the OP’s Macan.
#58 ·
Ackerman angle. Google it. Search. Its going to get worse in cold weather if you have summer tires.
#59 ·
Mine does the same thing. Apparently Porsche is looking into it. You can try disconnecting the plug on the transfer box and see if this problem goes away.
It's funny that Porsche claims "This behavior is currently a normal operating characteristic of the drivetrain and is under investigation."
If it's "normal" then why bother with the investigation.:unsure:
#60 ·
I've experienced something similar in my 22 GTS. Its happened on 3 occasions making a left turn into a parking spot. it feels like something with the power steering. I don't have PS+ so the steering is quite heavy and on those occasions it was like a PS+ function kicked in temporarily with a thump with the steering becoming noticeably lighter for a fraction of a second just before full lock. It doesn't happen all the time and I'm not too worried about it at this point but shall monitor it.
#61 ·
Yep. Mine too. 22 GTS. They checked it out and said it was a "normal operating characteristic" per bulletin.
Nothing normal about a loud thunk while making a turn. I'm sure at this point they know what it is and are doing the math on the potential recall/repair cost. Something tells me they're just gonna sweep this one under the rug.
#62 ·
Question: does anyone know "specifically" what is causing the noise?
#64 ·
Notice the same on a 22 base loaner with 650 miles on it when I picked it up. Had it for a month and I drove 350 miles. It did this numerous times taking a hard left at slow speed like pulling into a parking space, This does not happen with my 16S.
#65 ·
My guess is that the issue is much more common with wide tires. Hypothetically, imagine a three foot wide tire making a very tight ten foot circumference turn. The circumferences of the turning circles at the inner edge of the tire and the outer edge of the tire will be different. The path of inner edge of the tire around the turning circle will be shorter and the path of the outer edge will be longer. One side of the tire will need to be pushed forward to keep up or the other dragged backward. How weight is distributed over the width of the tire or the angle of tilt likely will affect what happens. As the radius of the turn increases the difference becomes insignificant.
The differences in turning radius from one side of a vehicle to the other is why locked up 4 x 4 should not be used on dry pavement. AWD is used on dry pavement to allow the wheels to turn at different speeds when turning.
#67 ·
It's the transfer box.
Technical Background
ONLY recommended for diagnostic purposes, fixing the degree of locking to a constant between the front and rear drive shafts from the transfer box serves to eliminate the concern. Disconnecting the electrical plug on the transfer box serves to fix or lock the torque ratio (diagnostic purposes ONLY).
#68 ·
crazy!! You would think they got this all sorted by now.. thanks for sharing this @kirkir !
#69 ·
My 2016 Turbo on 21's Conti's did this all the time on reverse.....more often when tires were not warm.
Recently changed to CONTI DWS 06+, GONE.....no matter what temperature.
I put it down to rubber scrubbing....
#70 ·
Mine does this occasionally and I am a former mechanic and now an engineer, but take that with a grain of salt. I believe it is simply the tire to rim interface that, during tight turns, is causing the tire to flex a bit and "pop" horizontal to the rim, but not breaking the bead.
Think of taking a corner extremely fast where the tire actually breaks it's bead to the rim. Now, imaging this happening slow in a tight turn, but because it is slow, the tire flexes and pops but does not break the bead. It's a hypothesis. There does not seem to be any mechanical noises produced so I am really not concerned.
