81 - 100 of 247 Posts
Mine is this one: https://aliexpress.ru/item/40005710...311.0.0.514f33edHppm73&_ga=2.88056029.430405436.1624300313-222361074.1624209140
I did not research if it has DSP or not. I suspect it's the same as joyauto technically though.
I ask because the DSP on this unit may help improve audio as it allows lots of adjustment on the audio.
I also like the fact with this new one you can use built in microphone and no need for external. Plus external supplied one looks like oem so for people without mics they can fit in same spot as factory
Santrix, in Dons link....there is actually install footage, as they add/install the daughter board. This may be the real deal !!
You install the board with joyauto too. If they just soldered the chip to the board without any changes to actual sound processing it may still use AUX with same poor audio feed.
Probably does but until someone tries it, it's all speculation.
I’m having second thoughts here, after doing more research on this. It’s seems you still need that external box. And based on the wire harnesses I’m seeing, it doesnt look that different from what I already have. The integration would not be different. You most likely be required to use AUX, although not sure, as I’m not seeing the AUX dongle - that may be an indication that audio goes in some other way... I’m not willing to use AUX for audio input. Is inherently of less quality.
The wire harnesses needed look almost identical…
243677
There is a box…. This lead me to believe that Is the same label of integration to other systems. Granted, improved, but if is not solving the issues I need, then I’ll be using it exactly as I’m using the one I have…. But, the lack of the AUX dongle is really throwing me off here. It could really mean AUX is not used.
243678
243679
Not sure about this. I still need to think about it. In the end, the only way to know for sure is buying it and testing it. But going through the effort to replace the one I have is a consideration…
It would be great to have access to installation and setup instructions.
The images are clearly wrong. If you check other sellers, the antennas attach to the board.
I did see that image so asked seller and he confirmed no external box.
What does the aux dongle look like that you are referring to?
see photo… is that dummy 1/8” plug you need to connect in the AUX input to make audio work. It seems this dongle fools the system into thinking there is something connected to the AUX plug.
243688
Hey Santrix, i am in communication with the Vendor, EBILAEN. They say it does not use AUX.
They are sending me the install manual.....I will email it to you.
Cool. Yes, please… send me the manual when you get it. I’m now more comfortable pulling the trigger on this.
