Why is the PCCB option not so popular?
43K views 69 replies 31 participants last post by  DanNYC
Ordered them on my new GTS. I love them and had had them before.
What's the reason...Cost
#3 ·
Cost - and what is interesting in that coming from the 911 / Boxster Rennlist Forums, most people who race their P-cars swap out the ceramic rotors for steel. They CAN crack under heavy load etc... so track guys will go steel. I had them on my 06 C2S and loved them but I'm already 100K CND on my GTS build and decided to stick with the standard turbo brakes.
I am sure your GTS will be SPECTACULAR.
#4 ·
I honestly can't see any reason to get PCCB on a Macan when Cast Iron brakes generally provide better stopping in normal operating conditions.
Evo magazine published a test between two F-Type Jaguars. One with and one without. The attached graph shows that the Carbon Ceramic equipped Jag only started stopping better than the Cast Iron equipped Jag after 14 consecutive stops from 100mph. Yes, that's right only after 14 consecutive stops from 100mph. When are you going to that in your Macan? On the way to the shops? Hauling the kids to soccer?
Indeed, when cold, the Cast Iron brakes consistently stop in a shorter distance than Ceramics.
On the track, There is no doubt that ceramics will perform better when put under a lot of abuse but normal people like myself who do not have bottomless pockets prefer Cast Iron on the track because the cost of replacement is cheap as chips compared to Ceramics if something goes wrong.
One small benefit of Ceramics is that they are much lighter that Cast Irons so they reduce the unsprung weight of the car. Benefit? Marginal IMHO.
The other thing you need to be careful of with Ceramics is changing wheels. If you are one of those people who do your own maintenance then you have to be very, very careful changing wheels incase you chip the ceramic discs. They are quite fragile. If you do, your done.
#5 ·
Of course when I win the Powerball, I will order the PCCB. :p
#7 ·
Porsche charges €5300 + labour to replace one disc, so besides the 8000 initial cost reasons there are another 5300 per wheel down the line.
Reactions: Quiquepas
#8 ·
Not original cost, replacement cost. $18K or so for rotors.
And for the track guys, that article has it backwards. Read any 911 forum and those with PCCB replace with steel when a rotor cracks.
There is the advantage of no brake dust, which a good thing, but on a SUV, IMO, PCCB is a joke (sorry). If the track guys use steel on the sports cars, PCCB on a SUV is massive overkill.
#11 ·
And they are really easy to chip when removing or installing wheels. A chip and they are done.
I've thought about them many times, simply because of the no brake dust. But there is simply no way to justify the expenditure to replace them. I could buy another car for the cost of new rotors and that is ridiculous.
I've never read a single thing, other than the lack of brake dust, where they come anywhere near the cost for road use. For track use, the verdict is pretty much in. Many serious guys go steel.
#15 ·
Reactions: MDJAK
#16 ·
I had them before, and I ordered them again on my new Build.
Love that the Brake stays clean, love the extravagance of the Feature, love the yellow colour which matches perfectly with White/red/blue/black cars.
Love the Performance eventhough in everyday use, you will hardly feel any differences.
That the PCCB is more likely to get destroyed is a urban legend from former times, nowadays the Brakes are capsuled in, and are not likely to get damaged by stones and stuff like that.
The only Thing to mention is that directly after a car wash the brake will react with a lag for a couple of seconds.
BR
#18 ·
Simple answer is No. See below for all facts. PCCB on Macan are ceramic both front/back.
Cayenne Turbo brakes:
Front: 6-piston fixed aluminum monoblock red calipers, 390mm rotors
Rear: 4-piston fixed aluminum monoblock red calipers, 358mm rotors
Macan Turbo brakes:
Front: 6-piston aluminum monobloc fixed calipers with 360 mm internally ventilated brake discs
Rear: Single-piston floating calipers with 356 mm internally ventilated brake discs
Macan GTS
Same brakes front as Turbo, but back brakes on GTS are 330mm (same as Macan S)
Macan PCCB:
396 mm cross-drilled ceramic brake discs at front
370 mm cross-drilled ceramic brake discs at rear
Six-piston aluminium monobloc fixed brake calipers at front, combination floating calipers at rear.
#20 ·
I don't have PCCB brakes on my Macan but, I do think that many like me , can afford a 911 but chose a Macan for it's functional space. Some wanted PCCB and others didn't . I always find it interesting that cost is related to a want for a 911 . That's cool but I want a Macan even though I can afford a 911 .
Just a different perspective :)
#25 ·
Everytime somone with a Cayenne or Macan orders PCCB, the accountants in the back office go .... Kaching. The marketing guys go Kaching Kaching! :laugh::laugh:
And when they are ordered on the sports cars BOTH those guys go Kaching, Kaching, Kaching :laugh::laugh::laugh: Because they know they not only sold them for the upfront cost but the owners will be buying steel when they chip one. :crying: The parts guys love those cars.
Porsche sure is smart :)
#39 ·
When I was shopping for my first Macan, I came across a CPO car at Porsche North Houston that checked all the boxes except it had PCCB. Decided to pass as I heard the prices for pads and rotors are completely off the charts and the rotors are easily damaged.
Thought this video would be interesting to anyone considering PCCB. While I don’t believe a PCCB brake job on a Macan is quite $15k, the cost is way way up there. Apparently this is one of the techs at Stevenson in the Denver area.
#46 ·
Why don't you believe it? For the rotors alone, an example
$4908 discounted times 4. That's $20K just for the rotors forgetting the labor. You don't think its real?
for spirited drivers and those hard on the brake pedal including during any “track” exercises, PCCB’s may wear out sooner than you anticipated. With replacement costs in the $20k+ range for front and rear, it might make you re-think adorning the sexy PCCB’s on your next Porsche.
Its very real and the reason, if you do some searching, guys who track go back to steel, unless you have deep pockets. This is new
Porsche has admitted that its expensive ceramic composite brake systems may not be the best choice for track days.... Upgrading from iron discs to carbon-ceramic rotors adds around $8,500 to the price of a new 911. A single PCCB replacement rotor carries a list price of nearly $6,500, or 20 times higher than the $330 iron rotors on the basic model.
#42 ·
So I assume the bolts suspected of being corroded can't be replaced? Ouch.
