Steering Wheel Alignment ?
8.5K views 10 replies 10 participants last post by  Humy
I recently bought a 2018 CPO Macan S and noticed shortly after I picked it up that the steering wheel was off center, to the left a few degrees (car tracked straight). Dealer agreed to take care of it at no cost at the 10K service. After I picked it up, i noticed that it is now off a few more degrees to the right. Service is going to take care of it again, so I have an appointment next week to see if they can get it right. Adviser mentioned that it is a delicate adjustment and they will do their best.
Just curious if there is anything special about the alignment on this car that should have made this so challenging? I've never experienced this before.
#2 ·
I recently bought a 2018 CPO Macan S and noticed shortly after I picked it up that the steering wheel was off center....
Just curious if there is anything special about the alignment on this car that should have made this so challenging?....
There are two ways to adjust the steering wheel alignment. The easiest is remove the steering wheel, and rotate it one or two splines in the direction you want, and then bolt it back on. But sometimes, the splines don't allow a fine enough adjustment, and the steering wheel is either slightly too far to the left, or slightly too far to the right. That may be what happened in this instance. When that's the case, the next step is to adjust the tie-rods on the front suspension. Normally, this is fairly easy to do as well, although it's a bit of trial and error, and you have to re-set the toe part of the alignment at the end. The thing about this that can be a little more complicated on a Macan is that some systems (like Adaptive Cruise Control, for example) have to be re-calibrated any time the alignment is adjusted. So in the end, it's not especially difficult, but it is more time consuming. Hope that helps.
#6 ·
What SoCalS5 said above is spot on. It’s essentially the same as most other vehicles.
No real magic to it. Yes it does involve a bit of trial and error, although the Service Advisor’s claim that it’s a delicate adjustment is sort of silly. Seems like merely an excuse for a shoddy job to me.
#7 ·
Step number one in an alignment is center the wheel. Then adjust your toe in at the tie rod ends.
Nothing new about this (or Porsche specific) in the past 100 years or so.
Dealer aligned my new (to me) CPO car shortly after I got it because the car was wandering on many surfaces. Turned out to be badly cupped tires.
Right as rain now.
