Replacing & Registering the Battery
436K views 1.7K replies 210 participants last post by  SouthJerseyRider
Hopefully I will not need to do this for 3-4 years but I’m curious. Manual p. 314 says only have done by Porsche dealer & you cannot tell what type of (aftermarket) battery will replace the genuine Porsche battery by the markings on the battery. WTF?!
I like Interstate brand. Often better quality than OEM but, that is for lead acid, not sure for AGM.
So, has anyone here had to replace their battery & did you have Porsche do it & what did it cost you?
I finally took a look at my battery which is under the trunk floor in front of the Bose SubW (After lift the cargo floor, must lift carpet & then lift another cover to view & if need to access/change it--would need to remove collapsible spare tire!)
I see mine is 92Ah.
I searched & found Gaudin Porsche offers two; a 92Ah & a more powerful 105 Ah.
958-611-105-21
BATTERY 105 AMP HOUR MSRP $543.76, online price $351.05
Replaces:958-611-105-20
958-611-092-21
BATTERY 92 AMP HOUR MSRP $439.44, online price $283.70
Replaces: 7PP-915-105, 955-611-085-00, 955-611-092-00, 958-611-092-20
So, if you wanted the same battery you have now you’d get the 92Ah for $283.70.
My guess is that to have Porsche replace it for you you’d pay MSRP $439.44 + ½ hr. Labor! ~$500 to replace a @#$!!** battery?!
For Lead Acid batteries, you just need the dimensions to fit the space & the correct Ah & then it is reliability, price, warranty & specs such as CCA. How can it be that much different for AGM types? If, for example, Interstate made one to fit Macan that was the same size with more Ah for ~ $150 it would be tempting. For now, until I learn that aftermarket brands are available & work well, I’d probably upgrade to the genuine Porsche 105 AH & DIY.
#204 ·
So in determining what monitoring tool I need for the 2020 Macan S I was looking through what peculiar things Porsche has come up that I wasn't aware of or encountered in the VDub/Audi world. So one of them is this battery "registration" when you're changing batteries. What's up with that?
And what if you just don't bother and just (when needed) install a new battery assuming the OEM one is dead? I know Varta doesn't sell car batteries here so (at least Audi and VDub) I'm used to Interstate. Will the car melt on the pavement, doors will fall off or won't it start unless you "register" the new battery?
Thanx for any enlightenment!
siberian
#205 ·
The car won't melt , but you could have drivability issues. I needed a new one in my Audi Q5,,same as my new Macan. Have a great independent shop and he said don't do it. In the car's computer you need to load the specs ,CCA etc. etc. into the computer, so it knows how the Alternator needs to keep it charged. No under or over charging. And if you unhook the old battery you can lose some of the computer programing. When they swapped it out they hooked up another battery to keep the 12v power intact.
#206 ·
Thanx ef1018! Will a 9v plugged in the cigarette lighter work to keep memory? Made a little box from parts bought at Radio Shack to put the 9v in and connected it to a a cigarette lighter to keep power whenever I had to disconnect the battery. Is the alternator water cooled in the Macan? What monitoring tool do you use assuming you did it yourself or did you have the indy do it?
siberian
#207 ·
Pretty tricky stuff dealing with the battery changeover. You apparently need the PIWIS Tester and someone that knows how to operate it. This makes it really tough for folks like you that live on the very edge of the flat world.
#210 ·
There is at least one other thread on this subject. OP, you will be interested in this:
I'm under the impression if you don't register the new battery it won't hurt the car, but the life of the new battery will be affected as it will not be optimally charged. I can't see how or why driveability would be effected.
The need to register new batteries is not unique to Porsche. Many BMW's have had this same requirement for years.
#211 ·
Thanx for the pointers and advice.
So I would thus surmise that somewhere in the bowels of the myriad computers is a small db which has all the batteries made that would fit a vehicle and upon entering the make/model/cca etc. it would tell the voltage regulator how much juice to optimally supply.
My latest vehicle is a 2015 so at that time Audi had not yet implemented it so it came as news to me. But it clearly is a major factor in deciding which monitoring tool to buy making sure it has this option.
Thanx again
siberian
#212 ·
#216 ·
It really seemed somewhat hard to believe that after so many decades of just swapping out a battery with another one with similar specs, that now the car computer must know details about the new battery to adjust the alternator charging.
But I think it is true, found this:
"How important is it to register the new after-market battery in BMW vehicles?"
Reactions: Mleibrock
#218 ·
My wife's car starts perfectly every time she attempts to start it. When I tried hooking up my Cobb Accessport tuner the voltage was measured at 11.8 V. So I hooked up my Deltran Battery Tender and trickle charged it for over 19 hours until it was determined to be fully charged. I recently purchased the iCarsoft POR-II Porsche OBD-II Scanner Tool Multi-systems ABS SRS (POR II) to use when servicing her Macan myself. I thought for sure I heard somewhere that this hand held scan tool could also register a replacement battery too. I have tried calling their Customer Service number listed but have yet to hear a person's voice. I have left countless voicemails with no returned calls or e-mails. Ieven used their e-mail contact with the same pathetic results......Nothing. I started checking the battery each night and it always shows up as below 80% charged. On the morning that I installed my most recent Custom Tune I made sure that her Macan was showing fully to be fully charged, yet when I installed the Cobb Tuner the battery voltage was still only showing to be 12.1 V. After the download was completed, I picked up two engine messages as well as 3 DME codes. . I looked into purchasing an INTERSTATE H8 (49) AGM Battery for this vehicle for $177.99 from Costco, but sadly found out that even though this INTERSTATE battery item # 1355853 with 900 CCA , 1000 CA, and an (Ah) value @10 hours is 95 Amp hours is listed on their website, not a single Costco store has access to this battery. So I ended up leaving with the only H8 (49) regular NON-AGM battery that cost me $132.99. Will it matter that this battery is not an AGM battery. I have not installed it yet because I wanted to find out if there is a hand held scanner available that can pair the new battery with the Macan. Any insight or help with this matter would be greatly appreciated
1: PSM FAILURE Consult a workshop. Adapted driving permitted
2: STEERING SUPPORT RESTRICTED. Adapted driving permitted.
3: DME CODES UFF00, P28202, UD123 No description available.
#219 ·
The electrical systems in your Macan and most every other newer German and many others is really complicated. There are numerous systems that interact with each other as you listed in your notes. ie driveability issues if the battery is not registered and it MUST be an AGM with all the OE specs . CCA and charge rate etc. I have an outstanding independent Porsche shop that let me buy the right battery NAPA had it in stock and charged me $60 to install and register it.
#221 ·
It is an interesting question though if it's really needed if you have stop/start shut off.
I have yet to replace the battery in the Macan, but if it's like the BMW, the registration process asks you if the battery is AGM or not. Assumedly the car adjusts the charging strategy based on the type of battery.
That being said, don't think I'm willing to be the guinea pig for trying an non AGM battery. There may be other factors that are way beyond my knowledge, and the upcharge for AGM batteries seems to be decreasing as they become more commonplace.
#222 ·
Thanks for the info you guys entered. I really was hoping to be able to by the H8 (49) AGM battery for $179.99 especially with Costco's incredible return policy but for some unknown reason they cannot seem to order that exact battery. So if I were to install a battery myself will my car still function or will I be left stranded and have to have it towed to a local stealership? Has anyone purchased a Scan tool that can register or pair a new aftermarket AGM battery with their Macan? My wife's Macan is a 2016 Turbo with 63K miles on it and a production date of DECEMBER 2015. Is this about the time that the batteries start to fail?
#223 ·
#224 ·
The "kicker" is the sticker on the battery....A BMS sticker. (Battery Maintenance System). Look on your OEM battery and you'll see the sticker. All that info from a new battery must be entered into the ECU to "register" the new battery. Trouble is, all the aftermarket batteries don't have the BMS sticker...Just the ones from the dealer.
#225 ·
NC Trackrat, how sure are you about the need for accurate serial and part number information?
After my experience with our X5, I came away with a strong impression that the battery part number and serial number were recorded merely for informational purposes and do not affect the charging strategy as the size of the battery, the type of the battery, and the age of the battery do, and that information might be used, for example, for someone working on the car at a later date to verify that the current battery was actually registered in case there are subsequent electrical problems with the car or there is a need to verify the age of the current battery.
Of course the Porsche battery registration system may be very different than what BMW uses, but the more I learn about it, the more it seems like it’s very similar.
#226 ·
This hostage Porsche holds over you for battery replacement is unconscionable. We should create a poll requesting whether Porsche should unleash the mystery of battery replacement so we normal people can walk into Costco and buy and register a replacement battery without going through a dealer.
#231 ·
This is getting old.
Technology from Porsche trickles down from the top of the food chain to the bottom. If I remember right, AGM batteries became standard in 2012 with the first 991.1, then onto the 981, not sure about the Cayennes. Macan came out in 2014. AGM batteries are robust enough to handle continually turning on the engine for start/stop. For start/stop, you can thank the environmentalists in Europe. If you want to understand how AGM is different than the old lead/acid batteries, go to Battery University and start reading. The charging voltage is different and battery chargers have different settings, that is, 14.4 vs 14.7V. They are supposed to be more sensitive to rapid charging and heat. In your MFD add the voltage to your display. You will see it move around from 12.5 to as much as 15.4, dependent upon what's going on. Its also temperature dependent.
Its not 1965 anymore. The car has a battery sensor. "Programming" the battery means registering with the computer the capacity, technology, series number, and part #. If you choose not to do this, everything I read says that the computer will think the old battery is there with its data, and more important, if you use the exact same part #, the old state of charge. So the car will be "charging" that new battery as if its near death resulting in a shorten life span. But since I'm not a Porsche mechanic, that's just what I've read. YMMV
Clearly there are now Autel diagnostic units to do the programming. Watch the video.
Complaining about this won't change a thing. Stuttgart isn't going to read some post buried in thousands of threads in one of dozens of pcar forums and decide "Hey, yeah, we need to go back to the old way of business and just make things cheap for our customers, pick up a DieHard from Sears, bolt that thing in, and done. Lets loose the energy management system we just spend $$$ doing R&D on to allow our cars to meet those EU emissions regulations and avoid the fines cause we want to ripoff the customer ?".
Sorry, but as "they" say. You can never go home. Progress is the future.
#229 ·
Standard lead acid batteries produce hydrogen gas when recharged. In an open environment like under a hood it’s not an issue. In your trunk the gas builds and becomes explosive at concentrations as low as 4%. This is why you must use a AGM battery in enclosed spaces.
Reactions: notmac1
#232 ·
#233 ·
While I’m not a battery expert, the way it was explained to me is that the gas is produced in an overcharged situation. AGM handle higher voltage charging well and don’t gas as much, but still need venting.
I think these AGM batteries are remote mounted because they really don’t like heat. It’s been years since I researched the topic and moved the battery to the trunk of my 57. That was a stupid amount of work, BTW.
#234 ·
According to the Battery University article I attached, AGM's are sensitive to overcharging. Wonder if that's the reason for battery registration...so that the vehicle can more optimally charge the battery according to it's capacity and age.
Never knew AGM's are sensitive to heat, but the article mentions that too. I always thought the reason for trunk mounted batteries was for weight distribution. Perhaps that's merely a secondary benefit.
