1,341 - 1,360 of 1,596 Posts
Seems so odd we dont have this feature in case I forget to lock.
You never get great technology with a Porsche, especially with a Macan (they are the last to get new features - just look at your key as a great example).
I’m still waiting for simple things that I had several years ago in my BMW, like heated seats that automatically turn on when the outdoor temp is below the level you set.
After I replaced my transfer case fluid I tried to reset the wear integrator but couldn't find where to do that. I just spent 45 minutes sitting in the car with the Launch X431 going through A LOT of menus but still couldn't find where to rest the number. HAs anyone successfully reset their TC wear integrator number with a Launch X431? If so, where did you make that change at?
Hello,
I have a 2015 Macan S diesel (211bhp) and I am looking for turning off start/stop permanently.
Looking for suggestions on a OB2 scanner that does exactly that, so if any has reprogrammed this functionality please let me know.
best regards
TSW
Yeah this just opens and closes the valve without sport or sport + @TigerMac so at least if I did a pse retrofit this portion would be covered without having to be in sport mode.
I may set it back to none from sga though, noticed zero sound difference on the base but hey it works through the x431 now at least :)
Couldn't keep my hands off this PSE thing (Launch: AirCon >Taste 5 Links >AGA) and it works. The Macan T develops a little more "droning" when idling, at e.g. 2000 rpm the sound has more "volume" and even in Sport and Sport+ mode there is an audible difference to the regular exhaust mode (but of course it's not the PSE HW sound from the Porsche website). However, I don't know if this all comes from this single exhaust flap control...
Interesting side effect, in Sport and Sport+, PSE mode becomes automatically activated.
Hello
can you give me instructions for piwis 3
One-Touch flashing Cycle" from 3 to 5
Thank you
Changed turn signal "One-Touch flashing Cycle" from 3 to 5
CODING:
Front End Electronics: Coding: Coding_0: Exterior Lights Parameters-One touch flashing cycles = {whatever number of flashing cycles you prefer}
Hello folks :) ...I used the search function, but did not find any real answer, so here is the question:
Is it possible to code the automatic closing of the windows/glass roof when it starts raining? The excel "cheatsheet" does not seem to give an answer either :)
Owning a Launch x431 PROS MINI.
Thx
...From a battery power savings point of view such feature would only make sense when driving and electronics is supplied by the alternator. When turned off, the camera system and associated electronics would drain the battery significantly...when driving, oneself is the best rain sensor anyway...
Yesterday I checked if it is possible to activate the seat memory for the driver's seat on a '23 Macan T with 8-way sports seats. No seat memory was ordered (might only apply to non-US versions).
Found out that my Launch did not list any seat memory module in the system list. Looking under the seat did not show any electronics box either.
After an extensive internet search I tend to the opinion that in order to retrofit the driver's seat memory one has to change the seat button module (motors connected to this directly w/o memory) the corresponding harness and add the seat memory module plus activate everything*.
- Am I right?
*including the button module in the driver's door...thought maybe I could operate the seat memory without door buttons, just by using the auto memory function with different keys
