1,101 - 1,120 of 1,597 Posts
Thanks. Is the sound change between open and closed valve subtle? I am not sure if I can notice the exhaust note changing when I go from Normal to Sport/Sport+ mode... :rolleyes: maybe I need to drive harder to hear the difference?
If you have the noise insulated glass like me then the sound isn't very noticeable from in the cabin until you go hard on the throttle, but standing outside the car you can definitely tell the difference from open/closed.
I noticed in the change notes for the latest Porsche updates that it reads as if there's an oil level function like the cayennes have to determine fill but I can't find this when I'm connected. Anyone have a clue or are these just FUD in the notes ?
There are oil values, I've posted somewhere in this thread about it, but there is a specific special function for oil fill level on the cayenne and it seemed like they added that. I'm going to email their support.
there are two options for this. One which works with reading the road signs via the camera and the other which uses the camera and the navigation data to display the speed. This is the better option and is called fussion mode. The modules that need to be coded are the instrument cluster, the head unit and the front camera. Although there are different options for us cars and a lot of people on the audi forum reported it didn’t work with us cars. So try at your own risk. I have enabled fusion mode so the speed limit works constantly regardless of speed signs on the road.
let me dig up the options for it from this forum.
but for instrument cluster you are enabling all speed sign options.
and for front camera you need to enable fussion mode and VZE.
Coding applicable for all versions:
VZA-Konfiguration: Allgemein Konfiguration Anzeigecodierung Anzeigetext
VZA-Konfiguration: Allgemein Konfiguration Anzeigekonfiguration in Lasche Mehr
Verkehrszeichen
VZA-Konfiguration: Allgemein Konfiguration Anzeige VZA bei 'Junction view' auf
Map Seite nicht aktiv
VZA-Konfiguration: Allgemein Konfiguration Anzeige VZA bei POPup's auf BC-
Seiten (nicht MAP) aktiv
VZA-Konfiguration: Allgemein Konfiguration Lasche rechts abhängig vom
Motorlauf ja
VZA-Konfiguration: Allgemein Konfiguration Lasche rechts im Reifendruckmenü
ausblenden ja
VZA-Konfiguration: Allgemein Konfiguration Lasche rechts in Info/Meldungen
ausblenden ja
VZA-Konfiguration: Aufhebungszeit Aufhebungszeichen Tempolimit 6 s (second)
VZA-Konfiguration: Aufhebungszeit Aufhebungszeichen Überholverbot 0 s (second)
VZA-Konfiguration: Aufhebungszeit restliche Zeichen 255 s (second)
VZA-Konfiguration: Anzeigezeit nach Kl. 15 ein 255 min
Codings applicable for RoW (= “nicht aktiv” for US)
VZA-Konfiguration: Schilder RdW Geschwindigkeitsbeschränkung aktiv
VZA-Konfiguration: Schilder RdW Geschwindigkeitsbeschränkung aufgehoben aktiv
VZA-Konfiguration: Schilder RdW Überholverbot für PKW (Rechtsverkehr) aktiv
VZA-Konfiguration: Schilder RdW Überholverbot für PKW (Linksverkehr) nicht aktiv
(remains „nicht aktiv“ as it covers right hand drive traffic only!)
VZA-Konfiguration: Schilder RdW Überholverbot aufgehoben aktiv
VZA-Konfiguration: Schilder RdW Ende aller Streckenbegrenzungen aktiv
VZA-Konfiguration: Zusatzschilder RdW Leeres Zusatzzeichen für dynamische
Inhalte aktiv
VZA-Konfiguration: Zusatzschilder RdW Bei Nässe aktiv
VZA-Konfiguration: Zusatzschilder RdW Bei Regen aktiv
VZA-Konfiguration: Zusatzschilder RdW Zeitliche Begrenzung aktiv
VZA-Konfiguration: Zusatzschilder RdW Nur für PKW aktiv
VZA-Konfiguration: Zusatzschilder RdW PKW mit Anhänger aktiv
VZA-Konfiguration: Zusatzschilder RdW Nur für Rechtsabbieger aktiv
VZA-Konfiguration: Zusatzschilder RdW Nur für Linksabbieger aktiv
Codings applicable for US (=”nicht aktiv” for RoW)
VZA-Konfiguration: Schilder US Geschwindigkeitsbeschränkung nicht aktiv
VZA-Konfiguration: Schilder US Geschwindigkeitsbeschränkung aufgehoben nicht aktiv
VZA-Konfiguration: Schilder US Überholverbot für PKW (Rechtsverkehr) nicht aktiv
VZA-Konfiguration: Schilder US Überholverbot für PKW (Linksverkehr)
(remains „nicht aktiv“ as it covers right hand drive traffic only!) nicht aktiv
VZA-Konfiguration: Schilder US Überholverbot aufgehoben nicht aktiv
VZA-Konfiguration: Schilder US Ende aller Streckenbegrenzungen nicht aktiv
VZA-Konfiguration: Zusatzschilder US Leeres Zusatzzeichen für dynamische
Inhalte nicht aktiv
VZA-Konfiguration: Zusatzschilder US Bei Nässe nicht aktiv
VZA-Konfiguration: Zusatzschilder US Bei Regen nicht aktiv
VZA-Konfiguration: Zusatzschilder US Zeitliche Begrenzung nicht aktiv
VZA-Konfiguration: Zusatzschilder US Nur für PKW nicht aktiv
VZA-Konfiguration: Zusatzschilder US PKW mit Anhänger nicht aktiv
VZA-Konfiguration: Zusatzschilder US Nur für Rechtsabbieger nicht aktiv
VZA-Konfiguration: Zusatzschilder US Nur für Linksabbieger nicht aktiv
So I go to instrument cluster, search for "sign" and set every line to "enabled" ? are you sure
Thats the one! You also need “comfort close” enabled and also the “acoustic close via fob” enabled for it to work.
Autel have told me the hba will be added on the next porsche update, so its a waiting game atm, but they will send me a update when this is done as they have logged a request on my device which is currently pending, should change to “completed” when done.
Curious if the HBA has been updated? Don't mean to bother but it's been 2 and a half months. Thank you!
This is an example where X431 and piwis differ.
To enable this with Launch, you will need to find each parameter required to enable....doable.
With piwis, you enable the feature, and it autocodes the associated modules.
PIWIS is the way to go in my eyes!
I have a 2022 so my vehicle did not come standard with Traffic Jam Assist.
Here are the instructions I found if anyone see’s this and wants to check them on their 2021+ with PIWIS 3:
“Changing option is not necessary to use on engineer mode.
upper 2021 macan,It has fontcamera and LWA(Lane warning assist)...
so we can activate PDLS to PDLS + ,LWA to LKA,LKA with TJA(traffic jam assist)
We can activate LKA ,we select front electronic ,instrument cluster,front camera,gateway and power steering and F12 and first step select piwis coding and second step maual coding and select option code 6I1 LKA.
If you have safety driving,and select GJ1 traffic jams at the same time.
two safety options will be activated after coding.
First I drive LKA only ,It is used for the upper 65km only..and not used under 60km.
But with TJA,If you almost drive automatically and safely under 65km ...more than my Audi Sq5 FLY.
Macan acc is not activated on 0km but Sq5 is activated on 0Km.”
They are both great tools. You cant beat the 431 for 2 second edits and its search function, for any big stuff...you need the real deal.
Hey guys, if I changed my boost gauge coding to show greater boost (changed the value to 1.66 per the recommended changes) this only changes the range it shows right?
it doesn’t change any of the algorithm that shows the boost? Like 17lbs was maxed before, and now it shows 19-20 sometimes now that I coded the gauge to show more. the car is stock 2017 GTS
I don't think anyone has been able to confirm that this works scroll back a little bit for @pierre458's posts and check out the unanswered question on rennlist.
