621 - 640 of 1,597 Posts
DRL (4-point LED or quad-LED) will turn off when headlights are on. For anyone interested in turning on DRL while headlights are on… here is what you need to modify:
Nice info - I'll add that to the my post. Mine stay on when the mains are on, and have always stayed on, by the way. Must be something for the 2019+ LED/PDLS+ Macans?
This is cool...for some reason....I do not have the below available to me in Launch I hacve checked (Ver 23.82 and 23.90)
Codiertabelle: Exterior Lighting: DD lights as marker light = YES
I do have the dimming parameter.........
I can't remember exactly what parameter but I found the setting for mine in the front end module. I believe it was under Coding. One of the daytime running light settings.
Also, looking at the spreadsheet, I was able to add the gforce meter to my keys, but from the spreadsheet i wasn't able to find
Board computer menu configuration byte 4-G-Force. Any ideas where else this could be (I was able to enable expert view). I can see the settings in the keys.
If you look closely inside the spreadsheet, it tells you that this requires additional coding. Look at the purple sections, there are 2 for this feature.
"Enable the G-Force menu (requires additional coding)"
interestingly I couldn't actually find those related purple items in the launch interface, but if I just used the function "Search for a coding Items" I was able to find everything with the search term 'force'
The terminology/wording differs from app rev to app rev on the Launch. Searching is definitely your friend.
Same for me, Teddis. V23.85 on my 2018 Macan S with PDLS. I see the dimming parameter (and I set it to 100) but I not see that other one. I did however these two similar looking in the Front End Electronics section. Unfortunately, after enabling both it still didn't work.
Hey guys, I'm new to this forum and 8 month old Macan S 2018 owner.
I've started using Piwis3 to do some light coding in normal mode such as interior light package and PSE, all was fine.
Now when I want to use the Engineering mode, I can not seem to figure out what I am doing wrong. I changed the mode to E in the menu and now I want to do the modifications from post 256:
(1) Kombinstrument: Dimmung - allegemeine Konfiguration: Konfiguration zentrales Zifferblatt Weiss = ja {Instrument cluster: dimming - general configuration: configuration central dial white = yes}
(2) Kombinstrument: Dimmung - allgemeine Konfiguration: Konfiguration alle Zifferblatter Weiss = ja {Instrument cluster: dimming - general configuration: configuration of all dials white = yes}
I have attached some photos, so after selecting Kombiinstrument --> Manual coding without coding rules (development) --> scroll down to Dimmung - allegemeine Konfiguration --> F12 Next --> I always get the screen from my last photo with "no entries set" message. So I just can not go further to find "Konfiguration zentrales Zifferblatt Weiss = ja" and "Konfiguration alle Zifferblatter Weiss = ja". No matter what I select from the list like "Bordcomputer Menukonfiguration" or other, the message is the same, "no entries set" on the next screen. If someone can help with some info, what am I doing wrong?
Thank you !
Thank you !
View attachment 251880 View attachment 251881 View attachment 251882 View attachment 251883
Looks like you have PIWIS 39.x or an early version of 40, where manual coding doesn't work properly. What exact version do you have?
By the way - you have definitely/properly enabled engineering mode, as you see all the text in German, but menus are in English.
Hi and first of all, thank you for your reply.
I have 40.400. The procedure for E mode was :
Go to Home->System->Diagnostic configuration for 991, 981, 918, 970, Cayenne from MY11, Macan
Go to Mode tab
Set Operating Mode to E
I also did it here:
Go to Home->System->Diagnostic configuration for other models-> Mode->Operate Mode->E (Engineer Mode)->Save
So basically the versions I have and not good? And I just can not use them for "manual coding without rules"?
Thanks
