So I am approaching 80K. Time for another PDK fluid change. Dealer did the last one.
I am going to try to do this myself over the next couple weeks, so here is what I have learned so far
1 - car has to be level
2 - you don't need to drop the pan
3 - here is the service kit - https://www.suncoastparts.com/product/PK95BTRANS.html
notice there is only a filter, not a pan
4 - you need to be able to watch the trans temp
I have the NT510 which has that capability
5 - the filter housing is external to the transmission
per the repair manual I bought
this goes along with that small filter in the pic of the service kit
Plan is to drain fluid, change filter, add 6 quarts, then go through the top up procedure which requires the trans temp to be between 30 and 50 degrees celcius
Any input before I F something up?
