98K views 167 replies 57 participants last post by  VAGfan
So I am approaching 80K. Time for another PDK fluid change. Dealer did the last one.
I am going to try to do this myself over the next couple weeks, so here is what I have learned so far
1 - car has to be level
2 - you don't need to drop the pan
3 - here is the service kit - https://www.suncoastparts.com/product/PK95BTRANS.html
notice there is only a filter, not a pan
4 - you need to be able to watch the trans temp
I have the NT510 which has that capability
5 - the filter housing is external to the transmission
per the repair manual I bought
this goes along with that small filter in the pic of the service kit
Plan is to drain fluid, change filter, add 6 quarts, then go through the top up procedure which requires the trans temp to be between 30 and 50 degrees celcius
Any input before I F something up?
#61 ·
Just for reference, my BMW’s ZF transmission fluid change costs $400-600 at the dealer, which is very similar to what OP did on the Macan.
My buddy has a lift in his garage so he and I did the fluid change on my BMW for the cost of the fluid plus a few shop items costing less than $100. It took 1-2 hrs. Before we started I took him out for lunch and we had a beer afterwards.
Guess we will do it again on my Macan for $200 something plus a lunch and a few beers. :laugh:
#66 ·
So seriously. This has the correct part number and is from a reputable company but is 1/3 the price. Would you avoid this? If so let us know. View attachment 211496
I for one would not hesitate to use this.
Looks like you have established that not only this is the product Suncoast is selling for the application, but it’s also the product your dealer used when they serviced your transmission before.
I will say that the dealer has a lot of audacity charging $38.99 a quart for something that they are buying for less than $10 a quart in bulk. I did note that they gave you a one dollar per quart discount off the list price, Woohoo!
#69 ·
Macan Tranny fluid change
Thanks for the write-up. You gave me pointers and confidence. Just did mine for the 40K mi service. And it runs and shifts great, thank god. I was a little nervous. It really was pretty easy. The exterior canister filter is great. That's any easy change. I only got 4 1/2 liters out of it, but that might be because I had it up on ramps. The hard part is the refill. I used one of those cheap $10 hand siphon pumps. The first 4 liters went in easy. Then I let it warm up and it only took another 1/2 liter. Its a little messy and drippy, but not too bad. That Suncoast kit looks perfect. I got the fluid from RockAuto, Pentosin FFL-4. I checked with Pentosin and they confirmed it is OE fluid. I got the filter and o-ring from FCP Euro. Not really much cheaper than the Suncoast kit, and I had to scrounge around for the drain plug washer because it wasn't included. Oh and it said "Put car in Park!" a couple of times after I was done, but that cleared after it saw the fluid level was good, but that scared me at first. I'm figuring on doing it at 30K mi. interval next time because I only got the 4 1/2 liters out of it. I don't have a scanner tool for the Macan yet so I was unable to monitor the fluid temp. I was looking at the Autel MaxiCheck MX808. Any suggestions? Coolant, brake fluid and plugs up next. Any tips?
#70 ·
It is pretty easy if you have 2 people to do it.
Brake fluid flush is just like any other car. I think there is a DIY here for the spark plug change. Coolant is usually good for 5 years/100k miles.
#76 ·
So I’m new to the forum but I’m staring at my wife’s Macan S in the garage and hoping I’m going to put the trans fluid in the correct hole.... this write up got me a ways along in this project but not very detailed at all.. am I pumping the oil into the 10mm plug on the drivers side of the trans? Or is there a trick I’m not seeing?
#79 ·
LOL some dealers charge less.
#83 ·
Here's a couple of things I found so far.
1. There are 2 ways to do this job. One is to just change the external canister filter and the other is to actually pull the pan off and change both the internal and external filters. This would explain the wide discrepancy in pricing.
2. We don't have to be so anal about temperature. Treat it like an oil change. Get it warm but not hot enough to burn the living s#$t out of you.
3. The fill procedure is quite simple. Fill it until fluid comes out the fill hole. Then start the car and let it run for a minute, fill again. Then start the car and put it into gear a few times and fill a final time.
hope this helps
#84 ·
I agree there are apples and oranges, but in this case I think we’re only talking apples. The Porsche dealer has absolutely zero intention of removing the pan. What they quoted me was the fluid drain and PDK filter only. Same as Indy. I would be surprised if any dealer quotes a pan drop as part of a regular PDK maintenance interval without the customer specifically asking for it.
#88 ·
I got the PDK fluid change kit from Suncoast for ~$200, but I don't have a lift and my Rhino ramps are too low.
Called around in SF bay area today: one reputable Indy asks for $700 including parts or $500 labor and one dealer quoted $970. Guess it is worth it to invest in a lift.
BTW, @Sl1 your Indy is quite reasonable.
#89 ·
Go ahead and remove the underbody panel. Then find a service station that will rent out a drive-on lift for an hour or two. Even at $100/hour, you'll come out ahead.
#90 ·
How do I find one? I did a google search and didn't find much locally.
The PDK fluid change procedure is very straightforward. I believe I can do a better job than most mechanics if I have or have access to a lift.
#92 ·
OK. Thanks!
#94 ·
Perhaps I need to build a new driveway first? ;)
#96 ·
But you still didn’t act after 12 years....... :sneaky:
Reactions: Photon
#98 ·
The local Indy here quoted $650-700 for the regular PDK fluid change and one dealer asked for $950. Dropping the pan is more work and materials, but I don’t think it’s necessary at 40k miles.
I got the kit from Suncoast for $200 and plan to DIY. The procedure is really not complicated.
#99 ·
I got the kit from Suncoast as well. Plan on doing my PDK fluid exchange next week.
Anybody use the Motive power bleeder to fill the PDK from below? Seems like it would be good.
Also - I do not have jackstands - but i do have a set of rhino ramps. Has anyone done the change with just driving up on ramps and not leveling out the rear?
#100 ·
Using ramps isn't going to provide you with much room in which to work... especially if you're rolling
around under there on a creeper.
As for level, if the vehicle is not pretty close to level, how would you be able to attain a proper PDK fluid refill?
I have done a lot of DIY on my vehicles over the decades and the PDK procedure is one I'm going to leave to
the pros - especially considering an internal filter refresh, as well as the external accessible filter.
#102 ·
I didn’t try it but it’s pretty tight there.
#103 ·
Thanks for all the responses everyone.
I will mention that I crawl under my car in "off-road" mode when they are on the ramps for my oil changes...I had loads of room for that.
I also put the car on ramps (front tires) and put the car in off-road mode while i did the transfer case fluid exchange. I still had a lot of room to wiggle around in there. Considering the transfer case is positioned even further back from where the PDK drain and fill plugs are located; I am certain I can squeeze in there without issue. I'm 25 and still can maneuver under the car without a creeper to consider.
I'm more concerned about filling the PDK correctly being that the car will be about 2 feet off level....the more I ruminate about this, the more I want to go get jack stands. Just adds another level of complexity to the whole job.
Side note - I disable the auto leveling feature after the car gets into off-road mode. NEVER go under the car with auto leveling still on.
#105 ·
Agree that the air suspension allows a bit more clearance which is very beneficial for a quick reach under / oil change without bothering with ramps (I can just reach under). That said, please do not go under the vehicle without a jack stand underneath each jack point. The air bag, valve set, or tubing connections could leak or fail.
It is absolutely not worth the risk - even for a quick reach underneath the vehicle or tire change. I unfortunately know of a family who lost a family member over Christmas this year as they were underneath a vehicle on a jack that failed.
oh and $2300 is highway robbery. Does the service include a whole new mechatronics? :)
