Hello all,
I have a 2015 Macan S 3.0 with about 118K miles. I recently just purchased the vehicle. Upon purchase I did an oil change with Liqui Moly and Ceratec. I also just did both motor mounts yesterday along with trans mount.
After putting the new mounts in, and buttoning everything up I am getting the following code:
P0016 Crankshaft Position Vis-a-vis Intake Camshaft, Bank 1 - Active
I have a pretty good OBD scanner and this code was not present prior to the motor mount job/oil change. The code is intermittent as in the check engine light does not always come on after starting. And the car runs absolutely perfect, no hesitation, no loss of power, no stumbling.
The only thing that was unplugged during the mount job was the electronic steering rack, which was plugged back in upon install. Now unfortunately I had to remove the suspension height sensors on both sides and that leads me to the next code.
000125 PSM Activation By All-wheel Drive Control
I did the PDK service per workshop manual, and the Pdk shifts like new. However when the car was up on the lift, I put it in gear and allowed the wheels to spin at slow speeds, I have a feeling the PASM panicked due to this and set off this code and all-wheel drive error.
I calibrated the electronic steering wheel end to end limits and SAS. However I am
not sure if I need to do any other calibrations because the “ride height sensors” where taken off and moved aside during subframe removal.
My car does not have air suspension, only the hydraulic filled struts that I can adjust via button.
The car runs and drives like new with zero vibrations now, so I guess I’m atleast happy about that lol but I need to get these new codes handled. Here are pics of the mounts, completely collapsed with hydraulic fluid leaked out.
