So yesterday was the day. At 5,600 miles the yellow warning message came on to add 1.0 quarts of oil, and the little yellow oil icon stood lit on the dash. I purchased and poured in 1-quart of Mobil1 0W-40. A few points:
The cap was easy to remove and the angle is a simple pour if you have steady hands (no funnel was required).
Kind of cool to be able to see the timing chain when the oil cap is removed.
The big thing: after adding the oil, I went to check the DIC for the oil level and got a message that said something to the effect that no information was available about the oil level at the current time. This went on for about 25 minutes and even survived a short park and shut down episode to run in a store to pickup lunch. Almost 30 minutes later, I checked one more time and the green bar was back that said oil level is correct. A quick search of some Porsche forums stated that the delayed update is normal. Now I am good until my first oil change.
Goes to prove that even with a factory correct break-in, a good engine can still use some oil. In my experience, most all of my Porsche's, especially the 911's used oil.
