Sound right but we have gone over this already in this thread. Every house has a wire, "bandwidth" going into it, whether its an apartment, townshouse, condo, or single Family House. That "wire" is "so" thick. It can carry a maximum number of amps at ONE time. Prior to WWII that standard was 30 AMPs. Post WWII it was 60 AMPs. From the 60s it was 100 AMPs. After Early - Mid 80s it was 200 AMPS.
100 Amps, today is not much. Just think about this.
You got the dryer on? 30 Amps max
Hot water doing its thing? 30 Amps
Its cold out, the electric house toaster is on (furnace) 60 Amps.
You want to cook at the same time on that Electric range? That could be 50 AMP if everything is on. Less ifs one burner is on and say the oven.
See the point? Guess what, you are OVER the 100 AMP maximum. Of course, that Furnace might not be using all its "banks" at one time, or the hot water heater might not be doing anything Put on the Microwave? Oops. They bet on you NOT using all those things at once. That was a good bet in 1980. Today?
See? Now you want to add ANOTHER 64 Amp box? LOL
I have read they try to mitigate this in some way by monitoring what is going on in ALL the circuits and just cut off the EV charger if the 100 AMPS is near capacity. But that is a Kluge. You can't live like that. Get the service upgrade and if you are smart, go to 400 AMPS. Don't be like the people who thought 200 AMPS was enough for ever. There could be a time you want FOUR cars all plugged in at once. Then what? That 200 amp service won't be enough. Think ahead and future proof.
Some houses come from overhead wires. But some houses have buried utilties. So to upgrade, they got to DIG UP the wires and replace them with thicker buried wires, trenching. Trenching cost $$$$. And you got to get in the queue, cause maybe they get to you in two years, if you are lucky, cause nobody wants to work anymore after the pandemic. And the utility company says there are "supply chain" issues. Go figure.
And THEN there is the distance from your electric panel to where you want the charger. If I did this it could be easy 60' from panel (that is after the trenching to replace the service) to where the sub panel or charger might go. Thats MORE copper and more labor
Get the point?
IOW, its all about "bandwidth" and nobody ever thought a microwave would exist, nm some EV charger.
Its also why I say the low hanging fruit has been picked. The early adopters probably had it easy, that is, enough power to begin and a short drop from panel to where the charger goes.
