21 - 40 of 152 Posts
Wife took a photo a few weeks ago and drove it to the shop . It turned out to be related to the solenoids . Rather than replace them which was a very detailed process they merely checked them and swapped them . The light went off but they documented it in case it happens again .
Interesting that yours said that it was ok to drive it and mine did not. I wonder if they changed the warning light between 2015 and 2017
Very scary when the car shuts down in "limp mode" for sure! My 2015 had the same message with "ok to drive" but just enough motor to crawl. Turning off the key and restarting brings back to life, but the dash warning lights can only be cured by hooking up a scanner and clearing. The Cobb Accessport has the ability to show the codes and clear also.
Macan flat bed towed to dealer today. Should have an answer sometime tomorrow.
Reactions: Louie Zoi
Update from dealer. Vacuum leak but still trying to find source
Sounds familiar. Some of us had this vacuum leak issue early in the ownership. You got no turbo boost so nothing serious.
I think the fix was to re-torque some bolt.
Reactions: mbr
But my dealer said they had to do an engine tear-down to trace the problem and it would be expensive without warranty.
Reactions: mbr
Have a 2017 GTS with 46,000 miles. Got a warning "Engine Control Fault", Driving permitted, Consult dealer". Car was driving fine, no problems noted. Took it into the dealer and they had to replace 2 crankcase vent valves because they were leaking air. Tech showed me the part and it was plastic with a round diaphragm. Tech says he has seen this problem before but usually happens with higher mileage. My part failure was "premature". Part numbers 946-107-229-77 and 946-107-230-77. They sit underneath plastic engine cover so easy to access. Covered under warranty, parts would have cost $200 ($100 each) plus labor. While I was there, they also performed ALA2 Recall for Fuel Pump Cover. Picture of one of the valves attached. All is well:)
Hey I just had this happen to my Macan. At about an hour of running it shuts off then refuses to start back up until its cooled down but the temp gauge is fine. Then, this time, it threw this error code.
Any idea on what this could be? Anyone have this issue?
I posted previously about this ENGINE CONTROL FAULT issue. When it first appeared, it had no performance related side effects. Eventually, I noticed it was laboring heavily in the lower gears, sputtering, but mostly in reverse, and only occasionally - it was not constant.
Originally, I tried something odd - i filled up with 87 octane and after about 10-20 miles, the fault went away. I finished that tank and did one more just like it. Once that was finished, I refilled with 93 octane. Within 1 day, the ENGINE CONTROL FAULT returned. It sort of feels like a rough idle or maybe slightly retarded timing - like if you were working on a classic car and didn't set the cam so it was rumbling - minus the rumble. Performance wise, the best way i can describe it is if you were driving manual and tried to start in 2nd gear. The issue goes away or is much less noticeable after 3rd gear, 25-30mph. Reversing out of a parking space though was at such a rough idle it almost felt like it was going to stall out but didn't. That got me to thinking - how can I resolve this? The first thing I tested was to use the car in manual mode while at a low speed. It immediately was more responsive and didn't sputter as much. I tried with the paddle shifters and the gear shifter, both methods all but eliminated the rough performance.
I'm curious about OP's fix though. If this were a fuel/air mixture issue, it would present either way, regardless of what shifting mode was in use. Now that I have isolated this to something that is more noticeable in automatic vs paddle mode, It leads me more to think it's a tranny issue, possibly vacuum related or computer related with the shift points. I won't even pretend to guess how all the electronics interact or how to resolve these things. Give me a 350 big block and I will tear it down and put it all back together blindfolded. All the electronic and computerized parts give me a headache.
I had a Land Rover years ago that decided it wouldn't start one day. I turned the key and just got a solenoid click. then hot air started blowing while the AC was on, radio was glitching and screen says Transmission Control failure. The car had good battery voltage and wasn't even able to start or turn over. After exhaustive research it turned out to be a $7 plastic switch that clips onto the brake pedal to turn on the brake lights. Yes a $7 plastic light switch (which I did not even need a screwdriver to replace), took down an entire rover. The vehicle was completely undrive-able. I couldn't even shift into neutral to get it onto a flatbed. It had to be dragged (kicking and screaming) out of my driveway locked in park. LOL. All that tech (and all this Macan tech are great when working, but you can see when even the slightest thing goes wrong, you're SOL.
iCanMacan....curious.......do you have a lot of soot build up on your tailpipes ?
If so, replace the AOS’s. It will disappear.....may be related to your problem......
AOS's meaning O2 sensor? I will check into getting those either way as I'm at 58k, wouldn't hurt.
Interesting - I did switch back to 93 oct and within about 10 miles the idle is now smooth in all gears, and in reverse. Really odd how it goes away like this - leads me to more of a timing issue. When it was presenting during auto shifting but not with paddle, I was more inclined to think it was a vacuum issue with the transmission. However, with different fuel, it cannot still be vacuum. Puzzling puzzle it is.
Got the same warning just last week: ‘18 Turbo w/32k miles.
AOS = Air Oil Separators........
Do a search on this.........if you are at 58K, I would do this simple swap, not expensive either.
i had this problem yesterday and brought in to the dealer. They said it was turbo charger and needs to submit the report to Germany for further confirmation. Germany came back and confirmed my turbo charger needs to be replaced free as it is still under warranty. But, the lead time is a week or so....mine is macan 2.0 and 60K on it...
