I just got this from my friend who has been helping me research this problem. This explains it completely and there is obviously a problem that Porsche knows about...
https://static.nhtsa.gov/odi/tsbs/2022/MC-10217269-0001.pdf
Advanced Technical Information
Bulletin #: 2222 3 Part ID: 3965
95B.III – 2022 Macan Transfer Boxes Shudder/Jerk at Slower Speeds Vehicles Affected
Models
Macan
Revision History
Revision
0
Model Year
2022
Release Date
July 29, 2022
Model Type
VIN Range
Vehicle-Specific Equipment
95B n/a
Original document
All
Changes
Condition
Customer uses adjectives like shuddering, jerking, jolting, lurching, lunging or similar to describe the behavior of the vehicle’s drivetrain at lower speeds. Particularly, this occurs while driving in 2nd or 1st gear in the transmission’s automatic mode with some slight brake application in combination with a greater steering angle input (at or close to ‘full-lock’), travelling at around 10 mph, e.g. while negotiating a parking space or lot. The condition happens in reverse too, and can be disconcerting. There are no fault occurrences associated with the behavior described herein.
Technical Background
ONLY recommended for diagnostic purposes, fixing the degree of locking to a constant between the front and rear drive shafts from the transfer box serves to eliminate the concern. Disconnecting the electrical plug on the transfer box serves to fix or lock the torque ratio (diagnostic purposes ONLY).
Service Information
Please determine if the customer’s complaint is consistent with the description provided in the ‘Condition’ section above, by first operating the vehicle under the described parameters (preferably with the customer). If this issue is consistent, please operate the vehicle under the same parameters with a fixed or constant torque lock in the transfer box, which is possible by disconnecting the electrical plug to the transfer box.
1. If the behavior identified occurs under the parameters described in the ‘Condition’ section above, and improves with unplugging the transfer box, then please DO NOT perform any repairs. This behavior is currently a normal operating characteristic of the drivetrain and is under investigation.
AfterSales
July 29, 2022 Page 1 of 2
2. If the customer’s complaint is either not consistent with the condition outlined in this bulletin and/or does not cease when disconnecting the transfer box’s electrical plug, then please continue to diagnose and resolve the complaint.
Warranty
As always, please document the repair completely in PCSS.
For this repair, please code the “cause” as follows: Cause location: 3965 Transfer box Cause symptom: 1126 Jerky gear change
Use the following troubleshooting labor operation
03350050
03350053
51921900
39650199
Search Items
Fault memory read-out
Creation of the VAL
Cover front remove and reinstall Unplug transfer box and test-drive
Transfer box, Macan, shuddering, jerking, jolting, lurching, lunging, transmission
