I bought a set of QuickJacks for my 2018 Macan GTS in the summer of 2022, to perform my 40K service. BendPak recommended the 5000 TLX, and it fits all my cars. They offered me the whole setup for $1599, all the rubber blocks, wall mount. They took 1/2 a day to setup and test, and cost me another $200 for the air compressor, air pressure gauge and ATF fluid. I bought them because I needed full access to underneath the car, and they did the job. As far as the fit goes, they are extra long, yet not too long and the range of cars they fit seems pretty broad.
What bothered me was everything about them, and the first 5 or 6 uses made me very nervous in 2022. This year in 2023, I've used them 4 times now, and it's seems to be routine and easier to deploy. This year in 2023, I used them to do a brake job on the Macan, and change the oil on my Ford Focus. I was using a floor jack and puck that I bought from Harbor Freight, in which I regret buying because of the jacks cup not being flat, so I don't use the floor jack anymore, and will probably sell the jack and get a better one. So far I have no regrets in the purchase and use of QuickJacks, and will keep them regardless of what car I own.
I don't use the double rubber blocks anymore, and just use a single thick one on each point. I check the air cylinders on every use, but they hold pressure for about 6 months for me. You can run a test first, raise them, and then lower them, and if they don't go down fast you need to change the air pressure in the air cylinders. I took a paint marker to mark the pressure relief valve on the pump, so I remember to open it fully, and I throw a towel over it, in case something bad happens. The locking arms are tricky to use, and you need to make sure they are in the locked position going up, and then let them down to confirm they locked.
My only complaint is disconnecting the hoses, where the quick disconnect collar turns out of position, and its hard to line back up to pull back on the collar and disconnect, something I can fix with a paint marker. Other than that, no complaints really.
