I don’t consider myself a pro, but I take you comments as a compliment.. of course, I’ll make a video…😊I want to also clean the carbon on valves too.
Please do a video on the coolant hose replacement if and when the time comes please. You are a pro at this ….,
How did you get it off? I tried pushing the clip in but the connector doesn't want to budge.Thank you - That worked perfectly and they came right off.
I can't seem to remove or see these bolts holding the engine harness in place. I swear to go it's like Porsche designed this to fail and not have "catastrophic damage" but worry owners enough. The coolant puddles nicely in the "V". The plastic clips are so brittle compared to any japanese or american car I've worked on.View attachment 230246
1 - Remove Bolts from Engine Wiring Harness, 2X, (Note. there is one on the Passenger side and one behind the Harness, towards the firewall). this will allow to lift the plastic wiring harness piece.
2 - Proceed to remove the Coolant Line from the Engine Cylinder Head and from the hose locate behind the wiring Harness.
Ha! they drove me crazy too. I found a youtube on how to do them. squeeze the blue buttons.I really appreciate this DIY and everything in this forum. I'm at an impasse on this DIY. Could someone please tell me how to remove these fuel lines? Please see the below images. Does this blue tab come out or get pushed in. I've tried both and neither seems to be doing the trick. View attachment 264012 View attachment 264013
If you find the torque spec, please post. Thanks!I cannot thank you all enough for this thread. Kaybee, your writeup is excellent! I have two questions for those of you who have tackled this repair on your own:
1) Torque specs. I know that this has been asked, but does anyone have access to the torque specs for reassembly, particularly the intake manifold? Also, I plan on tightening down in a star pattern - any reason why I shouldn't?
2) Is replacing the intake manifold gasket vital? I picked up the new Y pipe (honestly, not too bad - $90ish bucks at my local dealership here in Houston) but I neglected to buy new gaskets for the intake manifold. My only window to tackle this DIY is today right after buttoning up my time at the day-job so I need to run back to the dealership and pay up for the gaskets if I'm going to need them.
Thank you in advance!
Thank you! If that's accurate I definitely over torqued mine (I used 11 ftlb)OK - so far the info that I've found points to Porsche possibly calling the intake manifold an intake-air distributor:
And then the service manual states:
I cannot verify the torque. And this may be a reference point to follow up on.
I did this job last night and learned a few things.
1) Our 2017 S is just over 7.5 years old (we built it to spec and took delivery in March of 2016 weird though that may be) but has just under 40K miles on it. That kind of low mileage city driving has resulted in serious carbon build up (some of the worst I've seen but I don't get to look inside of many direct injection engines). I should have budgeted time for carbon removal while I had the intake manifold off.
2) The job requires a LOT of light. It's doable with one set of hands, but there are a couple of points where two sets of hands are valuable. If nothing else, bring a handful of zip ties to keep things out of the way as was mentioned earlier by another poster. The bolt behind the wiring harness at the rear of the engine bay is a no-joke nightmare.
3) The green plastic bracket that holds the back of the Y pipe down is another nightmare. It really, really does not want to let the Y Pipe go free. You will save ourself a lot of time and frustration if you cut the Y pipe right at the ridge just forward of that bracket so that you can slide it out (towards the back) before removing it from the rubber hose it slides into. I don't have pictures for an example, but you'll know it when you see it.
My 2017 GTS is at 93,000 miles, and it appears this "hose" just blew today. Coolant all over the street, and I had to get flatbedded home. I'm in Central florida, I do a ton of DIY, but just not sure I want to tackle this myself.I spoke with the mechanic again, he says this is a very common problem with the Macans. Probably something for buyers of used Macans to be aware of, that this should probably be replaced proactively. It sounds like it's just not the right material for that location and will ultimately degrade over time. I wonder what a good interval would be? Mine has 93,000 miles.
