I got the OEM vent tubing, but also got this Amazon vent tubing. I did install OEM. The Amazon knock off seems to be a bit more flimsy, including the connectors. Not sure if that will help with extending life… but in the end, I got it to get fitting dimensions as we will be manufacturing these fittings out of aluminum based on my design. I will be testing these soon.For anyone in Canada looking to do this repair (using the knockoff hose from China for the fittings). Parts can be had for about $100 including 2 x 5ft lengths of hose. I will try to reuse the original fittings if these seem of lesser quality.
Hmmm… Looks eerily similar to my design… 😉Getting ready to do this mod on the weekend. Hoping to just cut the hose off the fittings and not remove them from the heads, then push the hose down and use a spring clamp to hold things in place on the two fittings. The rest will get Oetiker clamps. Drew up a clamp to fit on the big hose to hold the little one in place. The first 3D print turned out quite well. Happy to share the STEP or sliced file if someone wants to print their own.
View attachment 289061 View attachment 289062 View attachment 289063 View attachment 289077
Yup. Your picture was the inspiration. Took me a few hours on Onshape to get it right, but my skills are weak. It's PLA but would have preferred ABS. Will try them out and if they fail, just make some more in a different material. Surprising that it printed without any support in the voids but turned out really well.Hmmm… Looks eerily similar to my design… 😉
What material did you use for printing these?
PLA won’t work… will warp. You need PC or other high temp resistant material… lets see.Yup. Your picture was the inspiration. Took me a few hours on Onshape to get it right, but my skills are weak. It's PLA but would have preferred ABS. Will try them out and if they fail, just make some more in a different material. Surprising that it printed without any support in the voids but turned out really well.
You're probably right. I will get some going in ABS tomorrow. Nylon is also available, but ABS should hold up.PLA won’t work… will warp. You need PC or other high temp resistant material… lets see.
Many folks have use this approach of clamping directly to valve with success. You’ll have no issues going this way….Will tackle it this weekend and grab a few pictures. I am actually thinking of trying the silicone hose direct into the purge valve on the side of the airbox without the 90degree fitting, if it works. Throw an o-ring into the locking slot on the nipple, pull the hose over the o-ring and clamp it behind. Gets rid of the 90degree angle coming out of the valve. We'll see if it's feasible or a failure point. I've got all the parts now except the spare hose with the fittings so will re-use the originals if it doesn't arrive today.
Perfect. thank you. Looking at it closer, it's just a ridge of plastic close to the top to slide over.Many folks have use this approach of clamping directly to valve with success. You’ll have no issues going this way….
