Nah… this was a very clever design…. Ready to burst exactly when your warranty runs out. That requires a lot of design experience, don’t you think? 🙂Maybe Porsche issued design of that part to an intern…
You can leave in place, but try to secure it somehow so that is not dangling loose in there. That‘s precisely why I removed it, because I didn’t want this to be dangling…@Santirx I’m getting ready to do this as my pipe just burst. In my mind I was just going to cut the plastic pipe, take the connectors off and run heater hose…at the end of your video it looks like you removed the rear pipe…I had planned on just leaving it. Looking at your highlighted diagram seems like it should be fine to leave in place. Thoughts?
Correct. That's the hose that connects to the bottom of the Coolant Reservoir. DO NOT REMOVE THAT ONE!Gentlemen:
Just to clarify, in both @Santirx 's second parts diagram (#11, or also labelled #12 thru #18) (Post 257) and in @Svetoslav Kostov's photo (Post 259), the part I have circled in red is not connected to the part we are removing, correct? It just happens to be shown in the parts diagram and that photo, and likely runs alongside our "bad" part, correct? We are leaving the part circled in red connected and in the vehicle, correct?
I don’t think so. This is a vent, so, normally you won’t have heat exchanged in a vent unless it is for heat recovery from vent to something else…. but this is not designed as an heat recovery system and in addition plastic is a poor heat conductor, so, if heat exchange is of primary concern here, they would’ve specified a metal tubing.I imagine they might have done this design to get the coolant to heat up faster? Not sure.
Thanks, any thoughts on if I use 2 orders of this hose, it seems to have slightly better specs and I can get it delivered quicklyI don’t think so. This is a vent, so, normally you won’t have heat exchanged in a vent unless it is for heat recovery from vent to something else…. but this is not designed as an heat recovery system and in addition plastic is a poor heat conductor, so, if heat exchange is of primary concern here, they would’ve specified a metal tubing.
I’m trying to rationalize the design intent, but have no idea why they chose this way…
Good luck with your repair.
I mentioned and again think a “Kit” would sell well…Has anyone put together a kit to bypass this line? I thought I saw mention of one...
The key about putting together a kit is the connection fittings to the engine. If someone can figure out how to machine these fittings out of aluminum or find these fittings as individual parts, then a kit could be put together at an affordable price. Otherwise it would be too expensive as one would have to buy the whole “Y” tubing just so that you can take out the fittings and complete the kit.I mentioned and again think a “Kit” would sell well…
