Are those thermoplastic shrink clamps you used? Do you have the link from where you got them?
That’s the first thing I noticed. They’re Gates PowerGrip clamps. I saw them offered on Amazon, as well as from other suppliers.Are those thermoplastic shrink clamps you used? Do you have the link from where you got them?
Yes, I did a video on the water pump and thermostat replacement. Still need to edit. The funny part on that is, about 3 years ago I had to do the same thing and documented a detailed process here in MF…. Changed thermostat, that failed, but didn’t replace the pump. The pump failed now (it was making noise) so this time I changed everything… and used my prior post in MF as a guideline… but will be releasing video soon.That’s the first thing I noticed. They’re Gates PowerGrip clamps. I saw them offered on Amazon, as well as from other suppliers.
Yes, this updated hose remedy will change the landscape on dealing with this annoying bit of “engineering” that Porsche stuck us with for this part.
Mine failed suddenly at 121,000 miles, and lucky for me, my indie mechanic did the job (in the traditional fashion) for just under $500, which I was happy to pay.
I’d say just get yours done. When it fails, it is sudden, makes a mess and you get the bright red warning telling you to stop driving immediately.
I was lucky on mine that it failed about a half-mile from home, so I limped it back.
Looks like we may have the makings of another great DIY video, eh? Also curious as to whether you documented the thermostat and water pump change as well?
No issues man. It was a great job. We wanted to understand it a bit better. But all the credit to you!Sorry, im not much of a videographer or photographer, just a mechanic. If i wasnt clear originally, i also cut that quick release fitting at the vent valve from its plastic tube, and reused it on my new 1/4" coolant hose. I just rotated it 180 degrees and pointed it at the front of the car. And yes those are themoplastic hose clamps. I didnt want big clunky sharp worm drive clamps on there. Just trying to do as clean of a job as possible.
They do have that “factory” look. Do they get hard once shrunken, or maintain some level of flexibility?..yes those are themoplastic hose clamps. I didnt want big clunky sharp worm drive clamps on there. Just trying to do as clean of a job as possible.
Mine was leaking and my bottle was almost empty. I did not lose more than maybe a few ozs of coolant. Yours might if its full, not sure.@dethbrd and @FRUNKenstein, when you removed the tubing, since this is a vent tubing, assuming it is not filled or is not significantly filled with coolant when car is cold.
So, as long as the car is cold, I won’t have to drain the coolant from the engine… to remove this tubing. Correct?
Yeah, that’s what I figured. The tank is at a higher level than the tubing. So, probably better to drain the coolant, replace the tubing and then refill. That way, I can pull vacuum to ensure there are no leaks. Draining and refill only take a couple of minutes…Mine was leaking and my bottle was almost empty. I did not lose more than maybe a few ozs of coolant. Yours might if its full, not sure.
@FRUNKenstein curious who did your work in the KC area?My tube had broken in multiple spots, so there was a lot of coolant that leaked. If you are replacing it before it breaks/begins to leak and doing that on a cold engine, I would expect there to be some minor coolant spillage if you don't drain the coolant, but not much. Full disclosure, it was my mechanic that actually did the work on mine. We discussed it, I showed him @dethbrd 's posts and got the parts. But he did the actual wrenching. He didn't drain the coolant.
I would 100% buy one (if I don't make it first)If someone started fabricating these …..people would buy them for the “day” , No doubt I would .
