New Android based Infotainment Option
I’ve been watching this space for quite a while but all of the options have been a little sketchy. Finally SDK Autos out of Australia looks like they’ve put together a decent package. The tech coupled with someone who actually speaks English as a first language gives me much more confidence.
Here’s a link to the video:
I’ve been emailing back and forth with Scott to get some questions answered. He sent me a list of FAQs which I’ll post below. He has a second video that is an of an earlier version but which also walks through a lot of interface questions. He quoted $1000usd +shipping. Let me know what you guys think. I’d like to get an installation video too just to see what I’m in for.
I’m going to get try to get Scott to come here to answer questions so he only has to do so once and we will all benefit.
Here’s the FAQ:
What does it do?
It's an Android Control Unit, that runs Android like a Smartphone or Tablet, it is adapted to work for a Porsche - with LVDS (Porsche Screen) in and out and Porsche specific jumpers and software. It runs via Bluetooth so all of your steering controls work, as does the digital display. It uses the car built-in Wifi for internet so I recommend buying a pre-paid SIM, or you can run it off a hotspot on your phone. It also has it's own GPS antenna for greater accuracy than stock. It's full Android, not just Android Auto so you can run any Android App with full functionality. Supplied with all hardware required and installation instructions and videos. And it works with the stock Porsche touch screen. The unit sits behind the PCM, no modification required and it all looks completely stock once complete and you still have access to all of the default PCM functions.
How do you install?
I provide instructions and videos with each unit but with a bit of experience, the install process is quite straightforward. Disconnect the car’s battery. It requires removal of the PCM (4 hex nuts), connecting the harness in 2 places (plug in/plug out) and clipping into the PCM power, earth and ignition lines at the back of the PCM. Place the GPS antenna under the glovebox and run the connecting cable along the bottom of the centre console (out of sight). Reconnect the battery and test the unit. Once the test is complete, disconnect the battery again. Mount the Android Control Unit to PCM via 3M tape (supplied) and reinstall the PCM back into the car and screw the PCM back in place. Reconnect the battery and enjoy Android in your Porsche!
What tools are required?
Tools required are a plastic Trim Removal tool (don't use a flathead screwdriver on your Porsche
) and a hex key set. A screwdriver set is handy but not technically required.
How long does it take to install?
Installation is approx 1.5hours for an inexperienced installer, 45mins for an old hat.
What is supplied?
All hardware including the Android Control Unit, Wiring and Harness, GPS Antenna, Microphone, Wiring Intercept Plugs.
If I’m using the Android interface and I get a call on my mobile paired to PCM what happens?
You Pair your phone (Android or iPhone) to the "Phone" on the PCM via Bluetooth as you normally would. You Pair the Android Unit that I supply to the Media Source via Bluetooth.
That way, the car retains all normal phone functionality and "rings" as normal, the call information appears on the instrument Binnacle on the Dashboard, your call contacts and SMS appear on the Porsche PCM as normal, etc.
Can I use my own SIM card in the Porsche?
Yes you use your own SIM (eg a 2nd line on your mobile plan) in the Porsche to provide the wifi in the car. The Porsche wifi will work with any SIM. You can hotspot off your mobile but running it off the Porsche wifi, with its own SIM, is recommended.
Do you ship to the US?
Yes but it can take a few weeks to ship.
Where are you located?
Sydney, Australia.
Will it void my Warranty?
It is fully reversible but may affect the warranty of the PCM unit (not the entire car), however it largely depends on your dealership, most of them are very reasonable when it comes to stereo equipment.
What issue may be encountered?
An incorrect installation will likely blow the 7.5amp fuse located in the fuse box in the passenger footwell (drivers side for RHD drive cars, left hand side for LHD cars). If this occurs, remove the unit, install a new fuse before attempting to re-install.
How do you switch between the OEM PCM interface to the Android?
Hold the "Nav" button on the PCM to switch between Android and Stock OEM PCM Interface. You can switch back and forth with ease.
What version of Android and how is it updated?
Android 5.1.1(Lollipop), updates via USB and apps update via Google Play Store.
Can I install any Android Apps on it?
Yes you can, any App that is compatible with Android. Waze, Google Maps, Gmail, Facebook, YouTube, Netflix, Chrome, etc.
How do you want to make a transaction?
- PayPal, happy to use Buyer Protection for your piece of mind.
Can I have it installed for me?
If the car is in Sydney Australia, yes you can.
How much does the unit cost?
Pricing is $1000USD including shipping.
Any other questions, just let me know.
Best,
Scott
Here’s the FAQ:
What does it do?
How do you install?
What is supplied?
Sydney, Australia.
Best,
Scott
