161 - 180 of 304 Posts
Be sure to test before fitting in. Everything checks out pop her in, of course after placing wiring and boxes behind new ac vent. Hope you have someone helping. I put the stuff behind then put in the 4 screws holding the ac vent in.
antenna lead is a bit too long, I used wire clippers to trim a bit on plastic off the end, about 1/4 inch, then applied silicon grease on it to help it slip over the plastic for the vents!
Im going to PM you, I’m helping my wife hang an art showing and will have no wifi connection for a few hours. Call with questions, glad to help you.
I love my Dually!
I really appreciate all the help. Everything works beautifully except for the rear cam which is a high priority for me. Once I get that sorted out it will feel like Christmas all over again!
Thanks! Can't wait to customize now. I'm waiting for the firmware file from Milo (hopefully tonight with the time difference). I'd like to change the "Turbo S" text to something else. Is it simply just changing the wallpaper?
If you have a Dually that has black motherboard with no ventilation fan built in and your airflow is weak, you should keep the center vents going, escaping air is helping keep the unit cool. Darn thing gets hot, hence the upgraded silver motherboard with a fan built in
Ya, I tried that too. Puzzling because seems like I'm the only one with the issue. If that White cable is not the video button, then the only thing I can think of is that the video wires in the main harness provided to me from ACAR might have been wired for PCM3 instead of PCM4. Or maybe there is a loose pin. After work I'll take a look again. Man, I'm dying for this thing to work, it's pretty awesome!
sorry I missed some messages
What is the question exactly ?
How to have the back camera working?
What is the issue? What do you see on the screen?
As I remember, when I installed mine, it was not working as the unit is setup for aftermarket camera and some configuration to do to put it back to oem one.
let me know if this is the issue and I will provide you the process to follow
Discussion starter · #177 · (Edited)
Updated dual screen BOOT logo. Original 2nd screen logo was a tad higher and not well centered. New images are now well centered. And there are a few to select from. Currently using v6 with new emblem...
Discussion starter · #179 ·
Sorry if I missed if this has been mentioned in the thread or the review video, but is it possible to turn off the second screen and keep the primary one on?
Nope... we have requested this to ACAR.
