Add subwoofer to Bose system
ICE
4.4K views 28 replies 8 participants last post by  jrb30
Trim:
Base
Year:
2024
Macan base model with Bose audio.
1) Is there a way to tap in to line-level audio (particularly in the rear of the car)? I hate using speaker-to-line converters
2) Is there a high current connection to the battery available (other than at the battery terminal) with either no fusing (I'll add a fuse) or very high current (100A) available?
Thank you
#2 · (Edited)
There are no Line-Level output signals available from the factory system. You would need a "MOST" adapter to convert the optical audio signals to a line level output.
I added a sub and amp to my existing Bose system. Easy install, as all the wiring is in the back. Tapped the driver door woofer signal at the Bose Amp (located in the rear left side), mounted the amp next to the spare tire, and added an 80 Amp fused wire to the battery terminal. The amp turn-on signal (ignition switched +12V) was connected to rear fusebox fuse #D4.
The sub box sits in the rear cargo area, with quick-disconnects in case I need to remove it for more cargo room.
Adds that clean low-end sound that is missing.
JL Audio CS110TG-TW3 Sealed PowerWedge™ enclosure with one 10" TW3 subwoofer at Crutchfield
JL Audio JD250/1 JD Series mono subwoofer amplifier — 250 watts RMS x 1 at 2 ohms at Crutchfield
#4 ·
I have an S model, but it appears to have base audio -- no Bose or Harmon-Kardon markings anywhere. Checked out the amp in the left rear, but it doesn't appear to have any optical connection. Any idea what wires would be speakers, so I can tap off to add a powered sub? (Not interested in high-end audio, just filling the bass end as the car has no sub at all).
#7 · (Edited)
I added the 12" Cerwin Vega powered spare tire sub. VPAS 12ST. You absolutely don't need any additional wiring or amp. You simply unplug the OEM sub and tap new sub wires into the OEM wires that go into the oem sub and your done. You have a long optional wired remote you can adjust 3 levels of bass and run under the side floor trim up into the center console area. The woofer itself is very thumpy and with deep bass. Itll put some bump in the trunk. If you leave it in the same area as the oem woofer itll fit but the flap will remain open about 1/2" which is probably a good thing to keep air circulating. you can try installing into the spare wheel by flipping it as well.
#10 · (Edited)
In the Base Sound System (not Bose, not Burmester), the factory amplifier cannot drive an added subwoofer. You need to add an aftermarket powered sub, or a separate sub and amp, and tap a speaker level output from the factory amp to drive the input of the added amp. The speaker wires are the twisted pairs coming out of that red connnector on the factory amp. You probably want to tap the woofer speaker of the driver door, wire colors (at the amp connector) are: Plus = White with red stripe. Minus = White with Brown stripe.
#11 · (Edited)
In the Base Sound System (not Bose, not Burmester), the factory amplifier cannot drive an added subwoofer. You need to add an aftermarket powered sub, or a separate sub and amp, and tap a speaker level output from the factory amp to drive the input of the added amp. The speaker wires are the twisted pairs coming out of that red connnector on the factory amp. You probably want to tap the larger speaker of the driver door, but I don't know which wire pair that is on the Base system.
So you can get the remote signal from the factory amp speaker wire outputs to tap into a powered woofer.
#16 ·
You can literally just unplug your factory sub amp, not the bigger amp behind the panel, then you can tap into the wires that were plugging into the factory sub amplifier. The sub amp is smaller and mounted to the sub enclosure. All the wires you need are there. Low level signal wires and your remote/turn on wire. I’ve had mine hooked up that way for 5 years. Zero issues. Very easy.
#28 ·
Concerning the connector on the amp, the release lever (pivot type) needs to be rotated about 90 degrees, and the force will increase as the connector body begins to extract from the mating half.
If the release is the slide type (rather than the pivot type), significant force needs to be applied as the connector body extracts from the mating half.
