41 - 49 of 49 Posts
Macan S 2015
Did this today. Its actually easier to do it trough the back side of the rear right wheel fender/shield (the black plastic cover between the rear bumper and the wheel area). Just remove 3 screws so you can bend it a little to leave some space for your hand.
For me, the sound is the same when its parked and I rev it on sports mode. However, when spirited driving it sounds a bit louder and you can actually hear a flow of air on the back side (like a flow coming out of the exhaust?).
When I first tried while parked I couldn't get any braps/burps and that worried me. But after driving it for 20 minutes and parking it back on my garage, there where all the braps/burps I was missing and I think they even sounded louder. Not sure why there weren't sounding when I was testing it at the beginning. Maybe the car was too cold? I did notice before doing the mod today that sometimes I cant get braps/burps and sometimes I do. I think its due to the temperature buy maybe some of you can comment further?
I also thought the car was a bit more quick? Not sure if its only psychological. But it felt really cool.
The valve triggers at 2450 rpm combined MAF sensor. There is some really good post on it. It mentions losing some low end torque too by doing the mode Per a Pcar advert on what it does. Basically, the valve opens and closes to different levels etc.
Interesting sharing, can u share more about the value wiring logic (bothe non-PSE and PSE will be fine).
From my study, my 2019 2.0 value keep open when coldstart, idle, gear1 low speed moving and pull over after runing, I am worry about my value didn’t work properly... but someone told me the value will close whe shift from gear1 to gear2, not have chance to verify myself yet.
You are posting the same thing in 2 different discussions? I added my comments to the last one you posted in probably best to not post the same thing in both.
I did this one, and enjoy it. It was very easy to access it from the passenger rear wheel well. Electrical taped both ends and tucked the plug up where it came from, not sure where to zip tie this thing down by the pipes.
Adds a lower tone to the exhaust and makes it slightly louder. In my opinion the bit more noise helps balance out the added intake noise from filters/intake/cobb. In the end I still want more exhaust noise though.
So you say this was easy to access from passenger rear well ? I looked could not see much…any tips ;)
Remove the 3 t25 screws holding the rear bottom fender liner section. I used a t25 socket and 1/4 in ratchet to do it without jacking it up. Pull liner back and shine a light back toward the bumper. Connector came off pretty easy. If I replace the exhaust it will be disconnected anyway, so I don't really see a drawback.
41 - 49 of 49 Posts
