1 - 6 of 6 Posts
Let me know if you have an idea of interchangeable part fitments for upper control arm between audi q5 and the macan
Discussion Starter · #3 ·
I believe they are all interchangeable.
I'll take your word for it,
I'm looking at the q5 upper control arm and also the macan upper control arm,
Both have an audi badge and it looks both have the same bushing size.
Even the shape of a set, front being a long and straight arm, and the rear being a short and curved arm.
I might go with the SPC's that has a 1.5 degree adjustment
but I'm wondering if I could also put powerflex front upper arm camber adjustable bushings which I've already ordered, which is a .3 degree camber adjustment.
-1.8 degree camber is all I need in the race track tbh, and this will also help in wet handling and braking.
2015 S, 1987 911-Sold
It seems many parts are interchangeable between Audi A4 all the way to the q5. For example Macan base calipers fit a4s.
I will be surprised if those parts don’t fit a Macan. A member here installed q5 lowering springs into his Macan S.
Let us know how it goes.
1 - 6 of 6 Posts
