Why is one tail pipe so shiny and clean inside
1657 Views 29 Replies 17 Participants Last post by  makeadeel
My drivers side - inside exhaust pipe is still looking much newer than the other three exhaust pipes. Is this normal?
I have about 2300 miles on the clock.
Automotive tire Motor vehicle Synthetic rubber Tread Automotive design
Automotive tire Wheel Tread Synthetic rubber Alloy wheel
Automotive tire Automotive design Rim Automotive wheel system Audio equipment
Wheel Automotive tire Rim Alloy wheel Tread
See less See more
4
21 - 30 of 30 Posts
In this case there would be also a very small benefit in hp when flaps are open ?
Probably. But it sure sounds faster. :geek:
The problem with this theory is that I don’t have a button to control the “flapper”.
Not a theory.
My 2018 Sports Edition has a button on the console for it. The system also activities during sports mode.
Not a theory.
The reason I used the word "theory" was because I don't have the optional Sports Exhaust system.
Are you telling me the standard '23 S exhaust system will close the flap I see in one of my passenger side tailpipes when I switch to the Sport mode?
I rarely use Sport mode and if that inboard driver side exhaust pipe only operates when the Sport mode is activated as the flapper closes in the outboard passenger side pipe, that could answer the original question about the very clean - new looking inboard driver side exhaust pipe?
I checked mine and the driver side - inside pipe is clean. In sport mode the passenger side opens, but the driver side does not. I think that's unusual. One would think they would both open. I have a service appointment on the 31st, so I'll be sure to have them look at it and let everyone know what is normal.
The 2019 Macan S I had did not have the Porsche Sports Exhaust, it had the normal factory exhaust, however I noticed when I swapped it out (briefly) for the AWE Touring exhaust, on passenger side there was an electrical connection to an exhaust flap on the outermost tip; I would imagine this opens up when at wide open throttle or cold start to sound cool, then closes once the cold start is done. If that valve remains closed the vast majority of the time then exhaust gasses will be routed through the muffler and out the other tip. A clean looking exhaust tip, to me, would simply indicate which one of your tips has the valve on it.
Turbocharged cars normally run a bit more rich (that means there's more fuel dumped into the stream than strictly necessary) to help with A/F ratios, that slight excess of fuel will create a sootier exhaust. Also, the turbocharger is lubricated with engine oil and will consume a small amount of oil over time, leading again to a sootier exhaust.
Both of the points above are to say that I don't think having a single exhaust tip that's less sooty than the others is necessarily a bad thing, it would just mean it's the one that stays closed most of the time and gets less "use". Naturally, any concern above that should probably be directed to the dealer to be 100% certain, and for peace of mind.
See less See more
Maybe you should read the owner's manual.
Maybe you can point me to the page that talks about how pushing the Sport button operates the flap and how that might relate to one shiny exhaust pipe. Thanks for any help you can provide.
...In general, direct high pressure injection engine operation mode causes more soot, just like Diesel engines use to do, that´s why my new 2.0l engine has already a particle filter (OPF/GPF). As long as this finds a way out, everything´s fine, no matter where...and where not...just consider it as a personal statement...;)
I can show you on my manual, but it's an '18.
I happened to come across this link on the forum, and based on it your car is normal from what I see.
From what I can tell, the standard Macan S exhaust has 4 outlets, and only one flapper that opens (inner pipe of passenger side), probably on hard accelerations as others have said, and the inner pipe on the driver side has a permanent restrictor that reduces exhaust out of that port 100% of the time
Starting at the driver side, my suposition on the 4 exhaust outlets are:
#1 Always Open | #2 Always Restricted =========== #3 Normally Closed [Full Throttle Open] | #4 Always Open
You could verify #3 by looking in the pipe after the car is warm and idling and NOT in sport, it should probably be closed. It might be open when you select "Sport" and the car is idling
See less See more
21 - 30 of 30 Posts
