1 - 6 of 6 Posts
Hi everyone, i just changed my oil on my 2017 Macan 2.0. When i opened the under panel, I saw this
232286
Anyone know what kind of fluid that is?
A look from the top looks like it's coming from this
232287
232288
I will be contacting the dealer, but just wanted to have an idea what it is so they don't give me the run around. Thx
Pink dots are coolant. The dry white / pink crusty. If below your coolant reservoir it may have just burped a little on a hot day, or sometimes they leak at the base of the reservoir (I can't tell from your pics). Where it's the 2.0L, check audi forums also as they'd have a much larger user base.
Discussion Starter #5
Thx for the reply. It doesn't look like it's leaking from the reservoir. It looks like it's leaking from a device that is behind 2nd photo, behind the alternator.
My car also leaked some oil too. The oil issue isn't too concerning to me.
Unless the leak is too evident, they should do a pressure test and find out what's going on, I'm not familiar with leaks on 4cyl engines.
Maybe someone with more VAG background can point out a common issue on that area.
Only thing I recall was on older 2.0 engines leaking from the head gasket but that should not happen on a newer engine.
1 - 6 of 6 Posts
