I think the leather steering wheel on my Macan is the best steering wheel I ever had in any car. And I had many nice cars. The car is 7 years old and the steering wheel is still like new.
TYVM! I will give this a try!YES!
@ RogieRog, You are holding/gripping the wheel WRONG!
That is 100% the cause of your sensitivity issue!
You do NOT need a new wheel or a wheel cover or driving gloves or anything other than a modification of your grip.
The reason for the change in expert recommendation from 10 & 2 position to 9 & 3 is airbags.
With hands in 10 & 2, when airbag in center of s. wheel goes off, it drives your forearm into your face with considerable force, probably breaking your nose.
In the 1st photo, your thumb PADS s/b in that yellow circled area.
Your thumbs should NOT be wrapped around the wheel & mostly on the inside of the wheel.
Let us know how this proper grip works for you.
FWIW, I was told, many years ago, by an advanced driving coach, that wrapping thumbs inside the wheel can result in finger/thumb breakage or even amputation during a crash. I was & still am somewhat skeptical about the amputation.
He was also against hand over hand technique during turns.
I appreciate the time you put into a reply. I will give this a try the next time I’m behind the wheel.For the OP and to understand better, this is the standard leather, multi whatever its called 95b.1 steering wheel. Refer to post 27, which is CORRECT
I was driving today and thought to see what I was doing and without thinking it was shuffle steering. I don't see why anyone would do anything else. Its the airbag. You WILL regret it if it goes off.
See the indent below. See where the steering wheel indents? Thumbs go there, NOT around the wheel. See the stitching? If your fingers or hands are on the stitching, you are doing it wrong.
Now, also look at post 27 for the CF wheel and here it is in leather. That bulge? I suspect its there cause Porsche is known for racing. Its what they "did". Thats 10 and 2 and since race cars have no airbags, if you are going faster, the bulge works. But not for normal driving. Think of it like the Le Mans start left hand key, a remnant of racing but functionally meaningless IRL. If in a timed event, I doubt anyone is worrying about an airbag going off but on the line.
I don't buy the 10-2 is a risk with airbags (assuming you don't have your thumbs hooked). I have yet to find any actual data that shows it is an issue.
Did you read any of those?! Support nowhere to be found.![]()
Driving with Hands at 10 and 2 is Outdated and Dangerous
Holding the steering wheel at 10 and 2 is dangerously outdated. Find out why.crosleylaw.com
Holding the steering wheel at '10 and 2' is dangerously outdated
www.businessinsider.com
pictures, you were warned
Airbag-induced thumb avulsion: two case reports - PubMed
Although airbags are designed to save lives and protect victims from serious injuries, airbag deployment can cause unwanted lesions. In this case report, two cases are presented of young women who sustained an important fracture dislocation of the first carpometacarpal joint (CMC I joint) caused...pubmed.ncbi.nlm.nih.gov
"If your hands are at the top of the wheel and an airbag deploys, there’s a good chance that your hands will be propelled backward and into your face at high velocity " ...nope, not what we are talking about.
"The National Highway and Traffic Safety Administration reports that improper placement of hands on the wheel when an airbag deploys has caused injuries such as amputation of fingers and “degloving”" ...and they don't define what improper placement is.
"If the driver's hands are at the top of the wheel when the wheel-mounted airbag deploys, they are likely to be knocked into his or her face. If they are at the bottom of the wheel, they will be sent sideways, and do no further damage." ...again, not what we are talking about.
"A driver sustains multiple fractures of the forearms and wrists driving her car with both hands over the airbag cover in a collision." ...once again, not what we are talking about.
"Two MN state troopers sustained fractured thumbs while resting their thumbs over the center airbag cover" ...starting to see a theme here? Not what we are talking about.
"A wedding ring of a female's left hand causes a large facial laceration just above the left eye while driving her vehicle with the left hand on top of the wheel." ...the theme continues.
...and then this article goes on to do an experiment that was poorly constructed. It appears that they think that if you drive at 10-2 that you must wrap your thumbs. Yet, when you drive at 9-3, you never do. But, it gets better: "Certainly drivers should avoid holding their hands in the airbag danger zone: over the top of the wheel, over the airbag cover, and on the bottom" ...say what? Where is the reference to not holding at 10-2?
The last one doesn't give any written details, but looks like once again this is about wrapping your thumbs.
Got any more that don't support the position?
...and that is what I am ultimately trying to point out. There is nowhere I could find that stated 10-2 with thumbs out caused a hand to hit a face/head, or another injury that wouldn't happen with 9-3 and thumbs out. Just a bunch of FUD being spread. Mmmm, tasty. Eat all you want of it.Many, go to NIH, there are dozens of reports. No they don't tell you exactly where the hands were, eg
😳Is Race-Tex the same as what Porsche used to call Alcantara? This is what it looks like after I tried to clean and restore 15 years of gunk from a never-maintained wheel on my recently acquired 2008 Boxster. It now has the texture of the fur of a child's well-loved teddy bear.
Uh, no, not really IMO. It is the movement associated with starting in the wheel hub, expanding outward to its full inflated size. If inflates in towards the rim of the wheel in 'all' directions.@Chinner, think about the position of your forearms, not your hands, when in 10 & 2 as opposed to 9 & 3.
Also think about the size of the fully deployed airbag, not the size of the un-deployed airbag steering wheel cover.
It should be obvious but, when your hands are in the 9 and 3 position, your forearms are farther apart and farther away from the airbag. So, you still might be injured but, there is less likelihood than if your hands had been in the 10 & 2 position. Obviously, if you were in the middle of a hand over hand turn or were driving one-handed with your hand at the top of the wheel, the airbag damage, due to forearm and hand striking face, would be greater.
I think you just catch fire before the airbag can get you.How does one shuffle steer a Tesla with a steering yoke instead of a wheel?
