My driver and passenger fans are not independent, at least not on the center dash vents. I can set the driver’s side fan speed to 1 bar and then, set the passenger’s fan speed to 4 bars. This changes the air flow on the driver’s side to match the passenger side. Of course, the display still shows as 1 bar on the driver‘s fan speed display.
Has anyone tried this on theirs or have the same issue?
I suspect my HVAC is messed up as I encountered other issues this past summer where I was running the AC, change the fan speed to about 5 bars (hot day) and nothing happened with the fan speed/air flow. In that particular instance, I even tried the MAX AC button. The displays reacted as they should (fan speed bars were max’d) but no change in air flow.
