1 - 14 of 14 Posts
2021 GTS with Sport Chrono question: how do you enable Sport Mode without the dial on the steering wheel?
I have swapped in a "loaner" steering wheel, that does not have the Sport Chrono dial, while I get some work done on my heated GT wheel. I really don't want to try and move the dial/electronics between the two steering wheels (twice).
Does anyone know how to turn on Sport Mode with no sport dial? To be more specific, because I have the dial, I don't have this button:
Communication Device Automotive design Gadget Grey Portable communications device
I assume it can't be done, and that's fine for a couple of weeks.
Discussion Starter · #2 ·
I clearly need to read MY OWN POST! I just need a little time with my x431.
Enable extra functions for "Joker" button (the steering wheel customizable/diamond button). Note: this will not enable features you do not have (Sport Plus, Sport Exhaust, PASM, Surround View, etc.)
  • Instrument Cluster: Board computer menu configuration-Board computer menu configuration byte 2-Joker Sport: Set to activated to enable Sport Mode in the joker button "Vehicle" options menu (confirmed this works)
  • Instrument Cluster: Board computer menu configuration-Board computer menu configuration byte 2-Joker Sport Plus: Set to activated to enable Sport Mode Plus in the joker button "Vehicle" options menu (confirmed this works)
Banned
Is there a manual to do this in PIWIS? I went in simulation mode - instrument cluster. But where do I go next? I can go to manual coding (in simulation mode) and can't find board computer there. Automatic coding fails in simulation mode. Should I expect board computer menu to be in automatic coding when I hook it up to the car? I'm using piwis 38.4
Discussion Starter · #5 ·
Not automatic coding. More like "Manual coding without rules", then search for Joker. Screen shot is from 38.2 simulator.
Make sure you're in engineering mode for your PIWIS.
Diagnostics -> Select the Kombiinstrument module -> Coding programing tab -> Manual coding without rules -> Select "All" then click Next -> then you will get a screen like below where you can use the search button for Joker, or just scroll down until you see the following:
Product Rectangle Font Screenshot Line
Banned
Thank you. Found it. Any concerns I should have before applying the change?
Discussion Starter · #7 ·
Make sure you understand what you changed, so you can change it back if something breaks. Also be aware that if you enable your Joker button to turn on Sport+, and you don't actually have Sport Chrono, then you're not gonna get Sport+ when you press the button. :)
Banned
Sounds good to me. 🍺
Does anybody know how to code or program the sports Chrono dial on the steering wheel I have a 2017 Macan fitted with an upgraded 2020 steering wheel and multifunction buttons and control module to suit does anyone know in PIWIS how to code this to work? I do have SC package fitted already
Discussion Starter · #10 ·
I would ask over in the "Hidden Features" thread.
It's gonna involve money because you don't have Sport Chrono (the system, not the dial). That's a feature you gotta pay for.
No I have Sports Chrono
Discussion Starter · #12 ·
I clearly can't read - you said that originally. Sorry.
I remember in poking around in PIWIS, there was a simple steering wheel type setting. I just gotta remember where that was. My concern would be whether or not your car would have (or recognize) the same setting. The SC dial in "new for 2019+" isn't it?
Yeah correct 2020 I think!! I would think some coding would get it to work…. I just don’t know where to go with the PIWIS 3 or if the Launch 431x Pro can do it?
Discussion Starter · #14 ·
This is definitely part of what you need to do in the Additional Menu -> Maintenance of Vehicle Data section of PIWIS (not where you do "normal" coding), but there has to be more around having the SC dial.
Rectangle Font Screenshot Line Software
1 - 14 of 14 Posts
