Anybody have a higher mileage macan transfer case go out? Mine is at 61k and it seems to be fine. And most of the failures I've seen here have happened under 40k miles. I'm trying to figure if you make it past a certain amount of mileage, that you may be in the clear?
Also with all these failures....what is actually failing? Is it mechanical, electrical, gears shearing, bearings getting loose?
I'm in the macan for the long haul, so any info on what actually fails on them would be appreciated! So that if mine does start to go out, I can just replace the worn part, not the whole assembly.
