I have Summer tires. ~ 22k miles so far. I ck tread depth in 4 spots across width of each tire each quarter. I recommend this so, you can be aware of any uneven wear or other problems & have time to correct the issue b4 ruining your tires prematurely. I have not had an alignment, do not need one since my tires are wearing evenly.
I started with 10/32 (You say you started with 11/32, which sounds right. Tire manufacturer should list tread depth, look it up.)
I'm now @ ~5/32.
I asked my Porsche SA if it is true that Macan's wear rear tires much faster than front & was told no, s/b the same. That is what I am experiencing so far. I will eventually replace all 4 with Michelins, which have a tread life warranty.
2/32 is the legal limit. If I lived in a rainy climate, I'd probably replace @ ~ 4/32.
Your tire wear is in no way normal!
Something is wrong.
Did you measure the tread depth? Those gauges are cheap! You can use the penny or quarter trick, to get an idea.
Obviously you have the issue of chunks falling off but are the rest of the treads @ 4/32 or 7/32 & is it worn evenly from inside to outside?
I would NOT go to the dealer for replacement tires. Now that you know they will not cover this under your W&T warranty why pay the Porsche premium rather than go to Discount Tire or some other reputable tire shop?
Have you kept proper tire pressure?
What CTP do you run?
Part load or full load?
Have you contacted the manufacturer with your photos to get their input?
Also, do the CTP yourself, 1x/mo. Do not rely on the TPMS for anything other than a rough guideline to point out a need to check it yourself with a gauge.
If you rely on someone else to check your TP (will not be CTP, probably Warm or Hot!) & rely on same mechanic to tell you what you tread depth is, you will likely get wrong information & wrong TP.
Due to; incompetence, laziness or outright lying.
Learn to do this yourself, it is easy.
Read this:
https://www.bridgestonetire.com/tread-and-trend/drivers-ed/tire-alignment
You can find many such articles & see photos detailing uneven wear due to alignment or pressure problems.
Nowhere, will it show chucks falling off!
I suggest cancel your new tire appt. at the Porsche dealer. Buy new tires, at a fair price, from a reputable tire shop (Compare fair price from tire rack.com.) & buy the road hazard warranty.
You can still use your (overpriced) W&T insurance... if you damage your rims.
