1 - 8 of 8 Posts
My 2017 GTS has a single button inside the rear hatch to close the door. I have had a couple newer loaner vehicles that now have a double button, one to close and one to close and lock which I found to be very useful. Does anyone know if this can be retrofitted to a 2017 model?
You don’t need to retrofit it.
Just use your key fob to lock the car before closing the rear hatch. The car will lock itself after the rear hatch closes, like a delayed lock.
Reactions: sboggs
My 2015 has this feature as well. I think its a package option or something to get it.
Reactions: sboggs
My 2017 Turbo has the two buttons so maybe it is part of a package.
Reactions: sboggs
Here is an excerpt from the wiring diagram - it looks as though the rear lid lock option uses another
wire (CLOSE LID BUTTON - yellow & gray and CLOSE BUTTON + LOCK - green & blue):
229410
Does your Macan have the green & blue wire? If so, you may be able to change the switch to the one with two buttons - although
what about the hole in the interior panel?
The back end of my Macan lowers to make it easier to load. I've never used that "feature". I don't use the lock feature either.
Pretty sure it's part of the Entry & Drive option (part of Premium Package Plus).
Do you have to insert your key to start your car?
1 - 8 of 8 Posts
