81 - 100 of 116 Posts
· Registered
Ok. All installed. Read instructions suggested. All good and easy peazy. BUT center intercooler grilles are a bit finicky—on outboard sides, the “tab” is really just a tension piece and can be pushed in with a
Modicum of pressure- at least more likely to not be lost as it will fall into the opening and easily retrievable. I tried with fingers, flashlight and mirror to find a hole, slit, tab or something to insert the arm into but nada.
All in all, pretty pleased and there is a 20% off code in Dec. Pano fyi.
· Registered
Ok. Thanks to NC Trackrat (R’lister)), the trick is to bend outward first the upper arm and then inward ( towards you) the lower arm to finagle into the slot. Solid now like upper and lower. Surprised because all other attachments “spot on” w/o problem.
· Super Moderator
Which version of the Turbo? 2014-2018 seems to have the lower and outer grill options:
Thanks!
My Turbo has the Sport Design front bumper (and mirrors). It appears the Turbo kit would not be an appropriate fit. 😭
I believe the Gen. 1 GTS came standard with the Sport Design front bumper (owners can confirm/refute). I see only the Gen. 2 GTS kit offered by
Zunsport to date on their website.
Maybe later?
Here's a side-by-side comparison of early Gen. 1 bumper options (S, Sport Design and Turbo):
237049
· Registered
Well, Zunsport or not, I decided a good do it yourself job should be better than nothing.
237879
Yes, it's a bumper off job and that means most will say that's too hard, but when your in there doing other things best take the opportunity as it comes. I am yet to be convinced that the plastic insert from the front type is anywhere near a 'good job'.
237880
Further, I don't think anyone has offered a 'complete' grill solution for the whole front. The mesh I used is 304 stainless welded 5.5mm x 0.8 mm, it offers excellent protection from stones and other rubbish and looks good too! :)
· Registered
2017 Macan GTS
@Gra great job!!!!
  • How long did it take to do this?
  • Where did you get the raw material stainless steel mesh? Does it come in black? I guess its probably easier to paint it black.
  • How much?
  • Do you have a DIY write up on how you did this? or pics?
i'm thinking the black mesh will look nice on a black/dark color Macan
· Registered
Well, I was worried everyone was asleep there for a while ...:sleep:
Thanks, I thought it looked acceptable.
How long did it take? Well I had to get in behind the front bumper for some upgrade work (diverters etc), that's about 1 hour to get the car up off the ground and get the bumper off. I then made cardboard templates of the pieces I wanted to make in mesh (four pieces required), depending on template skills that's about another hour. I then transferred the template shapes to the stainless mesh which I cut out with tin snips or diagonal pliers. The mesh panels were then curved at the edges and hand fitted to the bumper. The mesh was then secured with stainless safety wire (note very small holes are required in some sections of the bumper for this wire). This is the fiddly part of the job and can take about two hours if you are doing it carefully. Then it's a refit of the bumper.
I bought the stainless mesh from a local supplier who is connected internationally called Sefar (www.sefar.com.au), they supply all sorts of mesh from very fine to coarse, brass, stainless, welded, woven etc. The product I settled on was a welded 304 stainless mesh that was 5.5mm x 0.8mm under their part number WLD-6.35-08. It comes in a width of 1225 mm and you have to buy a minimum of $250 Aus, so that got me 5 m and I used about 1 m. I had to decide whether I wanted the woven mesh or the welded mesh, I was looking for max air flow and a reasonably unobtrusive appearance so I went for the welded. I also had to consider whether the mesh should be horizontal or 45 degree orientation and I chose the latter as the lower section of the main grill where the sensors are has a 45 degree artificial plastic mesh bit in it.
How much? Answered that in the last piece.
I chose plain stainless as my car is white with the bright trim, the PDLS lights have bright trim and the running and turn lights are also bright. The stainless could be painted but how well the paint would stick after some years and bug, stone strikes was a consideration. I think powder coating might be the answer for that.
238353
Making the cardboard template for the main sections. Note the hole required in the main large top template to fit the ACC radar, wire mesh over radar sections is not likely to give a good result! I also added 'pinch weld' around this hole in the mesh to stop nasty accidents with fingers - stainless mesh makes very nice 0.8 mm holes in flesh!
238354
The intercooler templates need to be cut to match the right shape as the plastic shrouds will mate neatly to the inner part of the bumper. A 10mm extra surround is added to the dimension template all around and this is folded at about 80 degrees to the flat face so the mesh wraps around the external duct shape. Note, there is a need to also cut a small relief where the wires enter the rear of the horizontal light bars so the mesh does not chafe the wire, this also enables the mesh to sit flat over the two small humps on the back of the light bars. (model specific here)
238355
Seen from the inside, note the sections of safety wire and the safety wire twisting pliers used. On this bottom section you should note I have added a section of 'pinch weld', a plastic U section over the top of the wire and safety wired over it, this is because this section is not bent with a return (like the bottom edge), it has to sit in straight so I added this to stop chafing and make it look neat.
238357
Here is the left intercooler duct from the inside, you might be able to see the two small reliefs (on the left side) cut to enable the wire mesh to fit the two light cross bars 'lumpy bits'. The carbon shroud is only placed to show how these parts will mate up on the car. The shrouds are normally fitted to the face of the intercooler.
238358
Finished product!
· Premium Member
Hello Everyone. I'm looking for radiator/intercooler grill screens from my 2021 Macan Turbo. Rennline doesn't seem to make them and neither does radiatorgrillstore.com which I saw an ad for in Panorama. Anyone know of an outfit that makes them for this car?
If you can find the right mesh you could make a template out of cardboard and use that to use a metal cutter scissors to shape the mesh. Then use Zipties to attach the mesh back through the cooling fins. Probably a very minimal cost.
· Registered
this is what i am going to use to make mesh grilles for my macan.
Mesh Grill
· Registered
2022 Macan GTS Gentian Blue
Mesh Grill
Be interested to see pics if you did this. The bill was $4k to repair a radiator on our Golf GTI last winter So I’m considering some protection for the new Macan.
These are now available but I don’t care for the upper grill aesthetics.
https://www.zunsport.com/en/product/category?path=76&filter=421
· Registered
Most cars do not have protected radiator or air conditioning condensers, and it is not uncommon for a rock to impact and cause a freon or engine coolant leak. For the Gen-1 Audi S4, and SQ5 (and probably other related models), later production got a plastic protector screen added over the vulnerable intercooler heat exchanger, due to road debri punctures and coolant leaks.
· Premium Member
Having installed this stuff on a Ducati motorcycle, it would seem you could get the aforementioned Amazon material, cut it to shape, and then use Zip ties to anchor it through the existing radiator/coolers. Would that work?
