Hope you don't need a new battery, but at least you can do that yourself (and code it yourself).Thanks for the tip! Unfortunately when I went out just now to try it, my battery is dead as a doornail 😖😭
Guess who ignored the suggestion to plug a charger in the car while coding. CTEK is on it now, so hopefully all is well in the morning and I can enable the setting.
The TPMS settings are controlled via the Instrument Cluster, which I basically "reset" with PIWIS. I have a feeling I need to use a newer PIWIS version and reset things again.Great news man !!! wonder how TPMS got caught up in that ?? may need drive time to register ....
What does it show or do you have a fault?The TPMS settings are controlled via the Instrument Cluster, which I basically "reset" with PIWIS. I have a feeling I need to use a newer PIWIS version and reset things again.
"No monitoring of time pressure. System learns over 15mph". However, if you go over 15 mph for a couple of miles, nothing changes. I tried changing the tire size, and tire type, and driving some more, to no avail.What does it show or do you have a fault?
How many miles have you driven. It can take a good few miles to give values sometimes."No monitoring of time pressure. System learns over 15mph". However, if you go over 15 mph for a couple of miles, nothing changes. I tried changing the tire size, and tire type, and driving some more, to no avail.
Drove it around some more - the fault message finally displayed: Tire Pressure Monitor Fault. Service Required. I know that's BS, just not sure how to fix it without going to the dealer. I will try using a PIWIS to retrain the TPMS (I see where to do it, I've never done it before).What does it show or do you have a fault?
Took me way too many tries to do it, but I have managed to retrain my TPMS sensors. Whether you use PIWIS, or an x431, the process is the same. Just be aware of one important thing: the car must be running. The first FOUR (!) times I tried, 3 with PIWIS, 1 with x431, the process "timed out" with the car switch "on" (engine not running) and connected to a 55amp power supply.Drove it around some more - the fault message finally displayed: Tire Pressure Monitor Fault. Service Required. I know that's BS, just not sure how to fix it without going to the dealer. I will try using a PIWIS to retrain the TPMS (I see where to do it, I've never done it before).
Did you do automatic coding? May be worth doing this as this will flash revert coding based on vehicle maintenance order.Drove it around some more - the fault message finally displayed: Tire Pressure Monitor Fault. Service Required. I know that's BS, just not sure how to fix it without going to the dealer. I will try using a PIWIS to retrain the TPMS (I see where to do it, I've never done it before).
Automatic coding is what started the problem.Did you do automatic coding? May be worth doing this as this will flash revert coding based on vehicle maintenance order.
I had a few issues trying to code LKA and LCA that kept ending in it faulting.
I changed the vehicle maintenance order and then did automatic coding and everything is now working LKA (had LDW but coded LKA) and LCA (already had).
So suggest trying automatic coding. If it still has faults try again but in another version of piwis! (37.250 coded okay but I still had faults I couldn't delete, tried the same with 39.500 and so far no issues and everything is working)
I am as good as I was before I monkeyed with stuff, but I clearly have a TPMS problem. There were supposedly a batch of Macans that got the wrong TPMS sensors, I appear to be one of them. I can manually train them, but they will not automatically train.Are you all good now @Runbuh ?
Once enabled you need to pull high beam stalk to activate the settings.So my battery is A-OK, my problem was that I accidentally left the bluetooth dongle connected and it obviously drained the batteryAnyway, all fine after a charge.
The setting under lights was there and disabled, so with great excitement I enabled the option and.... nothing. No difference
Thanks for the tips Run Buh, I'll try looking at those and as you say, won't just copy verbatim. Thanks too for the warning for the headlight settings, but sorry you took the pain. I was actually looking at those settings as they seemed inclined to be related, so glad I didn't touch them in the end.
