1 - 2 of 2 Posts
Suncoast sells the PDK clutch fluid and filter package but is that the same thing as the PDK filter and fluid? One maintenance schedule said you have to change the clutch fluid every 2 years. Another schedule doesn't even have the clutch fluid change in their list. Each list does show the PDK fluid change.
Underneath the car, is the drain plug behind the oil drain, the PDK or clutch fluid?
Macan PDK fluid change is the clutch fluid change. There is also a separate transmission fluid change.
1 - 2 of 2 Posts
