1 - 4 of 4 Posts
recently when I push the gas pedal to the floor when the car is in sport the pdk does not shift quickly and revs up and only stops this is I release the gas pedal
2018 Macan Sport Edition
I believe under the full throttle condition in Sport mode that you are describing, the PDK will go all the way to redline before shifting. If you let off the throttle as you approach redline, it will hold and not shift.
I suspect you may be lifting before the shift happens. If you want it to shift, keep your foot in it. If it still doesn't shift, that would be something to have checked out.
^this. In the manual for my Cayenne it specifically states that at WOT it will shift every gear at redline. Try using 99% and it should shift more optimally
1 - 4 of 4 Posts
