Porsche ChandlerWho is "they?" Scottsdale Porsche or Porsche Chandler?
I think this come from PCNA. They call small leaks… seeps, LOL!Porsche Chandler
I would certain NOT pay $1,600 out of pocket for an inferior & improper repair. (PCNA details the proper repair for this issue)...they found the timing chain cover leak. My SA told me NOT to pay for the FULL engine drop/TC Repair .... They will repair it without dropping the engine for $1600 bucks. ... have a rather good relationship with 2 of the SA’s and staff. Ironically, my SA was like ”well I know you want to go EV, maybe this is the universes way to tell you to go EV and not have to worry about oil leaks”
If Porsche covered the cost of the engine out Timing Cover oil leak fix, what would you have to pay to replace; water pump, thermostat, serpentine belt and tensioner?Might be bigger deal than just putting in 2 bolts. I think Porsche makes the dealer pull the timing cover and replace the gasket. This is a precision type job as they have to use a dial indicator to set/check install of timing cover, let alone for just dropping down the bloody whole contraption out of the car in the first place. I would get everything done at this point, water pump, thermostat, serpentine belt and tensioner.
I will let you know shortly…..If Porsche covered the cost of the engine out Timing Cover oil leak fix, what would you have to pay to replace; water pump, thermostat, serpentine belt and tensioner?
Not necessarily. I've got a 2015 Macan S, 61K and I just had the two-bolt fix done at my dealership for $113.49. Check the thread here: RUMORED: Possible 2-bolt "fix" for the TCC Oil...My indy just told me I've got a small TCC leak. 87K well past the warranty. I guess I'm effed...
