Thanks Santirx for the great video. How do you find its behaviour with the other video feeds, i.e. backup camera and parking sensor graphics? Do they still come up on-screen as usual, or does the module prevent them from displaying in CarPlay mode?
I haven't installed mine yet, as I am still waiting on the standoffs I ordered. I was thinking of taking the opportunity add a couple cameras, but it doesn't appear that you went this route.
Behavior with other video feeds is normal. When I put car in reverse, system will go to PCM rear view video. When placed back in gear, it goes back to CarPlay. Because it used PCM video, all sensors, all systems are present.
To your question, unless you specify aftermarket camera and connect to the quad harness, the system will transition to PCM and back automatically. To test, when you put in reverse gear, remember to take e-brake off…
To your questions about connecting additional cameras, in this case you will need to decide to stick with OEM it go full aftermarket (even for the rear). Not sure if going aftermarket will play with PCM, so you may lose PCM camera (unless you leave existing one, but then you’ll have two cameras in the rear).
I’m working on a review video as I have the unique experience of having installed 3 different aftermarket CarPlay systems in my Macan (Joye, Isudar and now Mr12Volt). I’ll go through all the benefits and quirks of each…
As you may have seen in the video, I had to remove the Isudar/Ebilaen board to install Mr12volt.
As a preview of my review, the Mr12volt solution is the best one by a long mile… in most aspects, stability and ease of connection, audio quality are far superior. PCM system integration is the best of the 3 system, except microphone. Isudar leverages factory microphone while Joye and Mr12Volt requires a separate microphone.
Installation is the most difficult of the 3 systems tested. Isudar is only an internal module, so no wires to route to passenger’s well and although Joye is similar in which it has an external module that requires wire routing to passenger’s well, I give the edge to Joye in installation easiness because wires are longer.
My priority had always been audio, having spend several thousand dollars doing a full audio system revamp, having an aftermarket system with native MOST25, is a significant plus for me. And Mr12Volt doesn’t disappoint.
